Old 07-24-2010, 11:35 AM
tkb289's Avatar
Default ERA FIA Tonneau Cover Questions
Have some tonneau cover questions ... trying do decide if I want to have a cover made for my car (ERA 2136 is still under construction). I use the one on my TR all the time, might be useful on the Cobra.
- Anyone have photos of their ERA FIA tonneau cover installed on their car? Interested in how it fits around the roll bar and forward brace.
- A lot of British cars use a tonneau cover design that is split down the middle with a zipper. Is the ERA cover set up the same way?
- If so, anyone drive their car with the passenger side covered? ( ... and yes, I know it doesn't work so well with the drivers side covered )
Thanks!
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
Old 07-24-2010, 11:40 AM
1985 CCX's Avatar
If you plan to do any overnight driving they are great! (Short of a soft top)
They keep the car dry, mine has the zipper so half cockpit is closed while rain driving......
Cobra Make, Engine: 396W Kirkham KMPS036
Sorry no photos. I use mine quite a bit. It keeps the seats cool while parked. The cover is not split down the center (ala European covers) because the roll bar diagonal interferes. It has velcro flaps that go around the roll bars.
I use mine while driving by simply folding the drivers side under the passenger side. Its handy on cooler days as it helps the heater warm the cockpit.
Check ERA's website for pictures.
Bob McLinden
ERA FIA 2080 SOLD
Kirkham KMPS036
Old 07-26-2010, 05:36 AM
Sorry, but I don't have any pictures of an FIA with tonneau cover installed. Maybe Bob Mc will take some pictures of his next time it's convenient.
The 427 cover, installed:
http://erareplicas.com/427/img/tonneau.jpg
Old 07-26-2010, 09:52 AM
tkb289's Avatar
Bob,
Folding the cover under sounds like a clever idea, does the cover flap or 'drum' at freeway speeds?
As Bob P suggested if you (or any other ERA FIA owners) have the time, any photos would be great. I took a quick look at the ERA website, found photos of the top, but did not readily see any pictures of FIA tonneau covers.
Thanks.
Build Log:
Old 07-26-2010, 11:11 AM
Folded under, it is not taunt enough to "drum". It does flap around abit but with all the other noises going on at highway speeds (our speed limits are 75 so we tend to cruise at 85+) there is no negative effects. I wish I could say the same for my hat.
I'll attempt to get some pictures in the next few days
Bob McLinden
ERA FIA 2080 SOLD
Kirkham KMPS036
Old 07-28-2010, 04:07 PM
jeffy's Avatar
Cobra Make, Engine: ERA 289FIA 2131, 331 stroker by Dan Dalena with 48 IDAs by Jim Inglese, AC Cars AC8 "Rosso Chiaro" (PPG Nexa code FG39) by Connecticut Custom
In your gallery, there is already a picture of your FIA with the cover installed...
Old 07-28-2010, 04:18 PM
Jeffy you're quick. I just uploaded three new pics of the tonneau both unfolded and tucked under. I will attempt to insert them here. The older pics don't show the details around the roll bar very well.
Bob McLinden
ERA FIA 2080 SOLD
Kirkham KMPS036
Old 07-28-2010, 04:20 PM
tkb289 here is the second showing how I tuck it under. Bob P if you want to use these for anything go ahead. There are some others in my gallery.
Bob McLinden
ERA FIA 2080 SOLD
Kirkham KMPS036
Old 07-28-2010, 04:40 PM
Guys, the point you're all missing is that the cover used when driving, is a speed limiting device. It will abrade the paint and stress the screw-in lift-a-dot pins in the fiberglass. The first time I drove with it half open going through 70mph, it immediately made me slow down and pull over to remove it.
Unless you 'parade' and go very slowly on the highway-use it when the car is parked in the sun only.
Chas.
Old 07-28-2010, 10:12 PM
tkb289's Avatar
Bob,
Great photos showing the cover, now I have a better idea of what the setup will look like ... thanks!
Build Log:
Old 07-28-2010, 10:14 PM
tkb289's Avatar
Chas ... I can understand what you are saying, at speed the cover is probably going to move around a lot, especially the faster one goes ...
Build Log:
Old 02-17-2011, 02:38 AM
xb-60's Avatar
I've always thought they were practical, but have no experience with them. I wouldn't mind adding it to my list, but....does constant use cause any damage to paintwork or stress the pins as ERA Chas alluded to?
Glen
Old 02-17-2011, 07:31 AM
I use mine when the car is parked outdoors to keep the seat cool and debris and leaves out. Works great, looks good. Forget highway use or be prepared for paint work.
Chas.
Old 02-17-2011, 03:50 PM
xb-60's Avatar
So if just using it when parked, no damage or noticeable wear to paint? Over what length of time have you been using it?
Glen
Old 02-18-2011, 07:21 AM
tboneheller's Avatar
Mine has been "tested" at high speeds with on damage. It works good to keep some water out when washing the car, & Lulu says that it makes a great cat hammock.
Old 02-18-2011, 08:49 AM
Glen
Being careful on and off, zero wear. Since about '92...
Chas.
Old 02-18-2011, 10:17 AM
jeffy's Avatar
Glen-
I'm the contrarian. After I saw the body of my car painted, I decided to minimize any distractions to the shape and eliminated both the the lift-a-dot snaps and the holes for the side-curtains, opting for art over practicality! Doug told me he was surprised by how much difference it made to the cars appearance:
Without a heater, this is definitely a fair-weather car. I'll stow a full cover in the trunk for emergencies!
Jeff
Old 02-20-2011, 09:42 AM
Cobra Make, Engine: ERA #766, FE V8, Toploader
The body certainly looks slick, but originality of appearance has been lost.
It all depends on what you want.
Old 02-20-2011, 11:31 AM
jeffy's Avatar
You make a good point, authenticity does suffer. However, it is easy enough to add the posts and holes if originality (or staying warm and dry!) becomes the priority, but it requires a repaint to delete them. Doug wouldn't even drill the holes for the "Powered by Ford" badges (he prefers no badges at all); he attached them with double-sided tape in case I ever come around to his thinking.
