Old 03-23-2012, 04:41 PM
Kramer's Avatar
Cobra Make, Engine: ERA 739
Default Leak from Diff??
just wondering some thoughts...I don't drive my cobra very often but i recently noticed some red fluid seeping on the bottom of the back diff. (the diff is the ERA outboard brake set up) (the tranny is a tremec 5 speed). There is a drain plug on the bottom of the pumpkin but I don't think that is where the fluid is coming from...looks like it is coming from on top somewhere where the driveshaft is.....
any thoughts....
Old 03-23-2012, 07:27 PM
Originally Posted by Kramer View Post
...looks like it is coming from on top somewhere.....
any thoughts....
Take a look from the back, upwards to the top, and see if maybe your vent tube has gotten dislodged/broken/leaking. Or at the very least you should see a telltale trail. Here's a pic of mine so you can see what I'm talking about.
Old 03-24-2012, 08:15 AM
Kramer's Avatar
thanks patrick...i did check that last night but that part of the pumpkin is bone dry. it is a very small seepage and the trail seems to point to the front of the pumpkin...i will spend some time with it today.
Old 03-24-2012, 08:56 AM
Unfortunately, it's likely to be the pinion seal. If it's not bad, I'd live with it for now.
Old 04-01-2012, 02:56 AM
Default depending on tools and ability to repair
Kramer if you have a drill press and tap set you can repair this seal in the car. Send P-m for info on how and phone# Rick L. Ps it's easy with a little work to make plate. Air gun with axle socket needed too. You will need new seal tephlon sealer and 4-6" pices of exhaust pipe that sits on the edge of the seal to install. Need to clear the pinion shaft.
Old 04-01-2012, 03:30 AM
ERA has its own seal instructions in the 427man section:
Replacing the pinion seal
