Old 10-02-2012, 06:50 PM
flaflier's Avatar
Cobra Make, Engine: ERA154 427 HR
Default Steering bushing
I have a question on the steering bushing (ERA154), the bushing that supports the steering shaft as it goes into the footbox.
As you can see, mine is a bit beat up, my question is, it it supposed to have a vertical split where the arrow is, or is that a crack and it needs to be replaced? I tend to lean toward a crack, but I figured I would ask.
Old 10-03-2012, 03:24 AM
The crack is normal. A little weird, but that's how they get the ball into the housing. The irregularity of the fracture stabilizes the housing when it's put in a tight mounting.
Old 10-03-2012, 03:54 AM
flaflier's Avatar
Thanks Bob, once I got it cleaned up, it looked like it was supposed to be there. Any particular grease needed, or wheel bearing is fine?
Old 10-03-2012, 04:49 AM
Theoretically, the shaft is supposed to rotate in the bronze bushing rather than the spherical bearing. I would leave the latter dry, and put a couple of drops of oil on the bronze bushing. It's an Oilite-type, so it absorbs oil.
Old 10-03-2012, 05:07 AM
flaflier's Avatar
Yea, that wasn't happening! That's why I took the bushing out in the first place, I couldn't get the shaft out! Bushing looks to be in good condition, a few minor scratches, but nothing major.
With the new steering shaft, it should now work as designed!
Thanks again Bob,
