03-11-2013, 03:36 PM
ERA optional rear suspension strength?
Does anyone know if the optional ERA rear suspension is stronger than the standard one (i.e., can handle more torque/HP)? If so, any idea how much stronger?
03-11-2013, 03:56 PM
SC
yes stronger, I've put 400HP through the back of mine when I decided to play with a supercharger a few months ago
03-11-2013, 04:40 PM
IL
Cobra Make, Engine: ERA #472, Previous owner of ERA #677 427, ERA 289 FIA-USRRC Street
Stronger...I have about 500hp and 500 lbs torque....you should be fine
"Some things get meaner as they get older."
03-11-2013, 04:58 PM
IN
Cobra Make, Engine: ERA 838
Hold on guys. How could it be stronger, both options use the same Jag 3rd member.
I have had both and the ERA option is very nice and very sexy.
John.
03-11-2013, 05:10 PM
I have the optional rear, and I'm pretty sure when I chatted with Doug in 2005, the answer was "No, it's not any stronger, just better."
03-11-2013, 06:59 PM
I know of a 580FWHP SB going through a Richmond that drag raced (on BB's). Frequently, will no ill effects.
Chas.
03-11-2013, 07:01 PM
With the ERA standard or optional rear suspension?
03-12-2013, 06:55 AM
Optional. The 'standard' rear is the Jag. The 'optional' is ERA's. It's either a Jag or ERA's.
Chas.
03-12-2013, 03:13 PM
Over built the car
03-12-2013, 04:30 PM
Rick, nice to see you back... and I agree, these cars can be very dangerous and, for a lot of us, less is indeed more.
03-12-2013, 06:01 PM
Originally Posted by RICK LAKE
Planning on using the "standard" but strengthened ERA/Salisbury rear with inboard brakes, Classic Chambered sidepipes, and Avons. I won't drag race or abuse the car, but I would like the extra roll-on power at mid-range RPMs. Peter and Bob at ERA tell me the 31 spline upgrade costs almost $2k and probably won't make that much of a difference, and that I could blow up even that with hyper aggressive driving. On the flip side, they seem to think the "standard" rear end is likely to be ok - even with the extra HP of a solid roller motor - if I don't abuse. I guess if I break it, I break it, and shouldn't sweat it too much.
03-11-2013, 07:11 PM
OR
Not necessarily any stronger since it uses the same basic components but the geometry it provides makes things a lot cleaner. Most notable is that it keeps the rear carrier indexed under loads reducing/eliminating wheel hop.
One of the best features is the way it looks. Very sexy. Take a look at the photos of it on the ERA web site.
DonC
03-12-2013, 06:35 PM
For the record-the 31 spline does make a difference. But heat-treated ring and pinion, side gears and L-19 bolts are vital for total abuse. That makes a difference for drag racing and snap shifts.
As Rick said, if you control the usage, it will live just fine without that.
As Brent says, that's why there's a throttle control.
BTW-a 'solid roller motor' is not 10 megaton bomb in the configuration you're planning.
Glad to see that you have adopted more pragmatic approach-now you're getting it.
Chas.
03-12-2013, 06:58 PM
Decided on the solid roller motor, btw.
03-12-2013, 07:00 PM
When do you think you'll have the car on the road?
03-12-2013, 08:06 PM
I get the kit end of April, painted, and the engine in May, +/-. From then I'm figuring on a year to build it, but if it takes longer, no problem. So that would probably be summer 2014.
