Like Tree1Likes
  • 1 Post By strictlypersonl
Old 04-11-2013, 04:06 PM
Cobra Make, Engine: ERA - B2Motorsports Dart 331
Default 351 to 302 - Location Differences
Are the engine mounts for a 302 and 351 located at the same place i.e. are the horns the same and located the same for all SB's?
My headers are stamped 351. Will I be able to use them with a 302? What are the differences?
Anyone run Trick Flow heads? Do the headers fit and properly locate with the ports.
Any other differences I should be aware of with respect to converting to 302.
x-cliff
Old 04-11-2013, 04:50 PM
Dunno about the mounts but the 302 is a 8.2" deck height and the 351 is 9.5". Exhaust ports higher on 351. See if T/F heads are 'standard' or raised exhaust ports on top of that.
Chas.
Old 04-11-2013, 04:53 PM
The header bolt pattern for the 302 & the 351 are the same but the deck height on the 351 is around 1" taller than the 302.
I believe the motor mount location is the same.
What this means is that if you install a 302 where the 351 was and use the 351 headers, the headers should be about 5/8" to 3/4" closer to the ground. That does not mean that you could not raise up the 302 to be higher in the frame. Do not know what else that might impact on an ERA though.
Terry
Old 04-11-2013, 05:15 PM
My understanding is the TF exhaust ports are raised 3/8" (1/2"?) maybe it will work out. I was wondering about any change of angle with the collector coming away from the flange or any change in tube length. I am hoping I can correct at the elbow if need.
x-chr
Old 04-11-2013, 05:18 PM
Raising the 302 would change your Cg-you don't want to do that.
Chas.
Old 04-11-2013, 06:54 PM
Exactly - hence my question on the height of the frame horns. I'm not raising the engine. TF rotates the valves towards the center of the chamber and then raises the exhaust port for flow reasons.
x-chr
Old 04-11-2013, 07:02 PM
Bob P. would know this-they build both deck-height motors into their cars.
Chas.
Old 04-12-2013, 05:37 AM
All the chassis stands are the same. Since the 351 primaries are built to compensate for their higher ports (relative to the 302's), putting them on a 302 might put them on top of the chassis rail. Higher-port heads would help and, while not ideal, I might consider shimming the engine up another 1/4". That might fit.
ERA Chas likes this.
Old 04-12-2013, 08:12 AM
x-chr
