Like Tree9Likes
Old 10-02-2013, 07:05 PM
prp289's Avatar
Cobra Make, Engine: ERA FIA 289
To CSCOBRA
Is it wise to install the suspension before painting the car, or just leave it on the dolly?
Old 10-02-2013, 07:14 PM
Leave it on the dolly.
prp289 likes this.
Old 10-02-2013, 08:33 PM
Cobra Make, Engine: ERA #766, FE V8, Toploader
Like PatrickT, I left mine on the dolly wheels. They stayed on throughout the entire build (including installing the front suspension) until near completion, when I installed the rear axle/suspension assembly and the engine/clutch/transmission assembly.
Again, the inside of my car was completely empty when I had it painted--only the body permanently mounted to the frame (on the dolly wheels) and the formed, ERA-installed main fuel line and main brake line (both running along the outside of the left frame rail) remained on the car. Not even the footboxes were installed--everything else was easily added later, after the body was painted (with the doors/decklid/hood/grille spltter/defroster vents/side louvers all OFF the car and painted separately). Be sure to note where the large "washers" are located when you remove the brake and clutch pedals and the pedal shaft (I masked those openings in the frame with painters tape). Take the usual precautions with every fastener you use (especially anything going directly into the frame) to reduce the chances of corrosion later on.
It all sounds harder than it really is--just take your time and do everything right the first time for every step before you move on to the next. This will save you MUCH troubleshooting time later on when you drive your new pride and joy away for the first time!
Old 10-03-2013, 05:54 AM
DanEC's Avatar
I painted mine with the body stripped and on the ERA dolly casters also. I did have the rear suspension and tank still mounted on mine but since I completely masked the underside of the car, the cockpit opening, the trunk opening and the hood opening while painting - that was not an issue.
Old 01-05-2014, 03:06 PM
prp289's Avatar
Default Happy New Years
Its been awhile since my last post. Like to announce ERA 2152 was ready to ship the 24th of Dec and I will be recieving a call monday from the shippers on ETA. Like to thank the staff of ERA for everthing, best purchasing experience ever. Here she is ERA 2152.
Old 01-05-2014, 03:42 PM
DanEC's Avatar
Congratulations - keep us posted on your progress!
Old 01-06-2014, 10:59 PM
Congrats on this milestone!
Once 2152 is in your garage, the fun really begins. By all means keep us posted ... and lots of pictures please
