Old 11-29-2013, 07:56 PM
Cobra Make, Engine: ERA 714
Default Turn Signal Indicator on Dash
The turn signals work on both sides, but the indicator is not lighting. I changed indicators and it still does not work. Checked that its getting voltage and it is. Is this likely a faulty ground?
Large Arbor
Old 11-29-2013, 11:12 PM
Gaz64's Avatar
Large Arbor
Seems you have answered your own question.
Only thing left.
Some more info would help, it's like answering "my car won't start".
Old 11-30-2013, 04:38 AM
Cars with a single dash indicator get their signal from the flasher. If the ground checks out, it could be a defective flasher.
Old 11-30-2013, 08:23 PM
I was thinking defective flasher. I will change it and try it again.
Large Arbor (aka Phil)
Old 12-01-2013, 02:42 AM
Cobra Make, Engine: backdraft racing, keith craft 408
Hey what type of flasher did you get? I haven't been able to find the exact one from my bdr at autozone...but I also did not receive a build sheet so I do not know what car to reference. Thanks
Old 12-01-2013, 04:56 AM
We use a Signal-Stat 180, but most any 3-prong flasher that fits the socket should work.
Old 12-06-2013, 08:56 PM
It is now fixed. It was a bad flasher apparently not producing enough current to light the bulb. I used a CEC DOT 550 12 V 32 CP max. Its working now.
Phil
