Old 10-10-2013, 08:20 PM
Default ERA FIA Front End Squeak
My FIA has recently started to develop a significant front end squeak / chirp. The car has about 3,500 miles on it and they have been squeak free until now.
Any recommendations as where to look first? Has anyone else had this problem? When I get a chance I'll take a look and see what's loose, thought I would check with you guys first.
Thanks.
Old 10-11-2013, 01:46 AM
mrmustang's Avatar
Gold Star Contributor
Thanks.
Lube the front end as you would any other car.
Also check your control arm bushings, I've had them go bad and crack with less mileage than your car has.
Bill S.
Old 10-11-2013, 03:38 AM
Default Start with sway bar bushings first
tkb289 All bushings need lube. Start with stablizer bar frame bushing first and grease them, Do all the ball joints upper and lower and retest car. If noise is gone have a nice day. If noise is still there need to do A arm bushings. Look at the bushing and make sure they are in good condition. If they look worn, replace them. I am not running rubber ones, I went to solid plastic for racing. I did add grease fittings to all bushings and grease channel to lube them after each event. Alot has to do with the grease you use too. I stay with Lucas high temp red grease. Not cheap but works good on both wheel bearings and bushings IMO still running the same setup from 98. I think after you do the stablizer bar frame bushings you will be OK. Aftermarket makes them from hard plastic to solid alumium. This is not hard job to do yourself. Have a problem, email me and I will walk you through the repair. Rick L. Ps at this time check the mounts for the coil overshocks. The mounts may need to be regreased. 2 bolts easy in and out with car on a floor jack and JUST taking the load of the front suspension.
Old 10-11-2013, 08:48 AM
Bill S.
Bill,
Good advice and I'll look at the control arm bushings. Thanks.
Old 10-11-2013, 08:50 AM
Rick,
Thanks for the detailed information. I'll start with the stabilizer bushings and ball joints. I looked up the Lucas grease, is it the Red 'N' Tacky #2 ?
It might be a little while until I have some free time to work on the car, but I'll let you guys know how it goes.
Old 10-11-2013, 09:54 AM
CHANMADD's Avatar
I'm with the lower control arm bushings.....mine is doing the same....
Old 10-11-2013, 03:08 PM
Also check the lower shock mount Rose Joint. I've seen them dry out and squeak. Pack around the joint with silicone grease.
Old 10-11-2013, 03:20 PM
RodKnock's Avatar
Tim, I'd check for mice. They tend to squeak.
Old 10-11-2013, 05:14 PM
Thanks Bob ... will check that as well.
Old 10-11-2013, 05:17 PM
Will do ... and if it turns out to be a chirp, then I will look for a bird ...
Old 10-12-2013, 05:20 AM
And if you hear a growl, it could be a bear. Be very afraid.
Old 10-12-2013, 09:11 PM
Bartruff1's Avatar
Cobra Make, Engine: Midstates/Shell Valley Street Cobra
Mine was a ball joint...
Old 03-25-2014, 03:12 PM
ack fia's Avatar
Cobra Make, Engine: ERA FIA #2039
Smile Front End Squeek
Look at the top of the front coil overs. This is an old problem that appears regularly.
