Like Tree2Likes
Old 09-25-2015, 02:42 PM
Default front battery access - can't get it out!!
How on earth do you replace a front battery on an early ERA with an FE?? I removed the valve cover, but I still can't figure out how to get enough room to wiggle the old battery out let alone get the new one in. Both are group size 24F. Any tips would be appreciated.
Thanks!
Old 09-25-2015, 05:28 PM
There should be a trap door on the back side of the passenger side wheel well. The battery doesn't come out through the top of the engine bay.
EDIT -- It looks like the early cars might not have that trap door. Check and see. If there's no trap door then you have to remove the valve cover and wiggle it out somehow. Hopefully you don't have to loosen the motor mounts and jack the engine up or something....
Old 09-25-2015, 07:04 PM
Cobra Make, Engine: Era 351, Contemporary 351
After you remove the valve cover it is a little tricky but you can wiggle it out the top and replace it.
Old 09-25-2015, 07:28 PM
Finally got it. It has to come out upside down and turned 90 degrees! For those wishing to know you have to tip the battery towards the back of the car (posts aim toward rear now), and then rotate it counter clockwise 90 degrees and pull it out upside down (posts facing down). Reverse for the way in.
Old 09-25-2015, 07:34 PM
thanks
Old 09-25-2015, 07:50 PM
Maybe you can retrofit a trap door in. Bob P. would know that. Here's a pic of mine from the last time I pulled the battery.
Old 09-26-2015, 05:59 AM
I've never taken a close look at that modification.
Old 09-26-2015, 07:55 AM
ERA 778's Avatar
Cobra Make, Engine: ERA #778 427SC Keith Craft FE 428 stroker
Another reason I am glad that I opted for the trunk installation of the battery!
Hal
Pete Munroe and 66gtk like this.
Old 09-26-2015, 02:42 PM
Hal
But have you checked your corner weights? With aluminum heads, intake, water pump, flywheel, and lighter components the car is butt heavy. Shocking, but true....
Old 09-26-2015, 03:46 PM
Nothing wrong with a little rear wheel weight bias. I don't think you could find a race car built after 1910 that didn't have that.
Old 09-28-2015, 05:04 AM
DanEC's Avatar
What I would like to have seen on the ERA would have been a bit lower battery location more like the originals and then the solenoid could have been mounted per original on the rear of the wheel well. Also it would have put the weight of the battery down a bit lower. But I understand the difficulty that creates with most people installing SC side exhaust and the cost advantage of using the same header ends for the street undercar exhaust - just not enough room.
But if someone, someday takes on building another street roadster from ERA and wants to look at fabricating some block hugging headers for it, modifying the battery box bracket to shorten it looks like a pretty simple task. It would be a task customizing header to clear a lower box - just not much room to work with due to the rise of the main frame rails.
ERA 782 Running
Old 09-28-2015, 06:30 PM
LMH's Avatar
LMH LMH is offline
Look at how clean that car is! Do you drive that all Dan?
Alba gu brąth
Old 09-28-2015, 07:41 PM
DanEC's Avatar
I took that series of photos of the underside right after finishing assembly. Still fairly clean but sort of dusty now. Trying to drive it but still working on a few bugs - latest is a leaking fitting on the oil pressure gage.
ERA 782 Running
Old 10-05-2015, 11:01 AM
Cobra Make, Engine: ERA 427 S/C, Ford 427 Side-oiler 2x4 bbl
After the corner weight discussion a few months back I brought out my scales and weighed mine.
I was totally surprised to find a perfect 50/50 weight bias, and corner weights.
I have a iron head 427FE SO 2-4bbl with trunk mounted batt.
I can't remember if that was with my bigg butt (200lb) in the seat or not. I'm thinking it was.
Phill Pollard
Old 10-05-2015, 04:37 PM
Phill,
What's your chassis number? Later cars lost front weight via an aluminum radiator and finally aluminum inner panels after ~730.
Old 10-06-2015, 02:07 PM
About the original post, I wish I had seen this earlier, I just did it on #598. I had changed the battery several times with no problem by removing the right valve cover, but the last time it just would not come out (I didn't try turning it upside down). I looked at it and thought for a second, and realized that the outer end of one of the rocker arms at a critical location was up, so I put it in fourth gear and rolled it backwards about two feet until the tip of the rocker moved down, rotated the battery sideways and pulled it out, no problem.
Oh well, lesson learned here.
Ken
Old 12-24-2015, 04:56 PM
Originally Posted by strictlypersonl View Post
Phill,
ERA #446.
Phill Pollard
Old 12-26-2015, 07:07 AM
ZOERA-SC7XX's Avatar
Now that's good to note. A little tid-bit like that can really make your day. Thanks.
Old 12-26-2015, 08:03 AM
If you have one of the older cars, putting in wheel well venting, along with an easy-access trap door, is a nice weekend project. That will kill two birds with one stone.
Old 12-27-2015, 11:23 AM
1985 CCX's Avatar
I found wiggling it out with a spot from below was huge.
Also needed to do it this was on a friends Ace.
One guy on floor pushing weight up. Supporting the spot.
Top guy doing the articulation.
