Like Tree1Likes
  • 1 Post By patrickt
Old 02-11-2016, 11:21 AM
Cobra Make, Engine: ERA 289 FIA 351Windsor
Default ERA carpet removal...
I'm considering buying a street version ERA289 and making it more of an FIA car. 2 questions: How are the carpets installed in an ERA? Are they easy to remove but will it leave an adhesive or screw hole mess making it tough to go to the bare aluminum look? The car was built at the ERA factory. Also, will it be difficult to install the roll bar at this point?
Thanks!
Kim
Old 02-11-2016, 11:32 AM
DanEC's Avatar
If the car was painted and assembled by ERA you would probably be well served to call them and talk to Peter or Doug about your questions. The problem with the carpets is even if ERA doesn't normally glue them down, most buyers of painted rollers have to remove them to install the engine and transmission (they may even be shipped loose with the car) but the owner may decide to do so on his own. So the current owner can probably tell you if they are glued down or not. Adhesive would be used on the rear bulkhead and the transmission tunnel. Also some owners might have glued down some insulation on the floors under the carpet.
The car might already have receivers welded to the frame to mount a roll bar. I suspect the 289 car does not have them. Again, ERA could tell you and the owner should know.
ERA 782 Running
Old 02-11-2016, 11:38 AM
kevins2's Avatar
The ERA build manual has illustrated instructions showing spray adhesive is used to install the carpeting. However, as Dan pointed out, buyers could easily go their own way, so best to confirm.
Old 02-11-2016, 02:26 PM
Bernica's Avatar
Senior CC Premier Member
It seems to me that in the big picture of things, just pull the carpet and preserve best you can however it is currently attached. If you can save them you can always use them for templates for new stuff. I would personally rather have it all glued down as opposed to velcro or other such.
My 2 c...
Old 02-11-2016, 04:02 PM
Call Peter to check, but the mounts for the roll bar should be there, but you'll need to make some holes. Ripping up the carpeting will not be that difficult and this stuff will remove the adhesive residue. You can get it in bigger cans, too.
[ame="http://www.amazon.com/3M-08987-General-Purpose-Adhesive/dp/B0002NUO6K/ref=pd_sbs_263_2?ie=UTF8&dpID=414YffWsfAL&dpSrc=si ms&preST=_AC_UL160_SR160%2C160_&refRID=1CMDFQ1S1KS P9HHDHNAN"]Amazon.com: 3M 08987 General Purpose Adhesive Cleaner - 15 oz.: Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/414YffWsfAL.@@AMEPARAM@@414YffWsfAL[/ame]
ERA2076 likes this.
Old 02-11-2016, 04:08 PM
In my 427 ERA cars, the trans tunnel is fiberglass. Only the floors under your seats and supporting your feet are aluminum.
Old 02-11-2016, 04:20 PM
Well, that's a good point.... But, ERA will sell you an aluminum tunnel cover to fit your vintage car if you ask them nicely.
Old 02-11-2016, 05:14 PM
Cobra Make, Engine: Era 351, Contemporary 351
ERA 289 Fia cars have aluminum tunnel not sure on the Slab side
Old 02-11-2016, 05:31 PM
ERA went to aluminum tunnels starting with the car before mine. I think the FIA cars always had them, and I can't imagine the slabs don't use aluminum.
Old 02-11-2016, 05:57 PM
Murky781's Avatar
Cobra Make, Engine: ERA 781, 69' 428CJ, PPG BLACK. ERA 3005 Arctic White 331 SBF
Slabsiode tunnels are aluminum with glued carpet.
We make 3 bad decisions a day. Choose them wisely.
Old 02-13-2016, 11:52 AM
OK...great info! Thanks! I'll grab a can of the remover when I get to that end of the project.
