November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree1Likes
  • 1 Post By strictlypersonl
Old 03-28-2016, 12:43 PM
Cobra Make, Engine: ERA 289 FIA 351Windsor
Default ERA 289 Fuse Panels...
I searched thru the manual and I may have missed it but I need to know what fuse goes with which circuits. Is there a page in the manual that labels the fuses? If not, can someone give me this info, not only for the two fuse blocks on the firewall but also the 2 fuses under the steering column?
Thanks!!
Kim
Old 03-28-2016, 03:08 PM
P.M. sent.
Old 03-28-2016, 03:13 PM
It's towards the back of the manual, around page 146 or so on mine.
Old 03-28-2016, 04:05 PM
Thank you, Gentlemen! My panel lights aren't working and that gives me a good place to start.
Kim
Old 03-28-2016, 09:11 PM
Dangerous Doug's Avatar
Cobra Make, Engine: ERA 289 FIA #2108
ERA can supply you with a schematic. Otherwise, I can scan and send you a copy of the one that came with my 289 FIA. PM me if you want a copy.
DD
Dangerous Doug
"You're kidding, right?"
Old 03-29-2016, 06:15 AM
The panel light rheostat is notoriously a (bad word). I recommend that you just connect both connections to the same terminal, since the ability to dim the dash lights is not used very often.
Pete Munroe likes this.
Old 03-30-2016, 08:38 PM
Ha! I saw your post, Bob, a day too late! The rheostat WAS the culprit and I pulled it apart to see what I could find...corrosion...I tossed the pieces in the trash and ordered a new one from the UK. $50 with shipping. But I like your idea of just shunting them together on the switch...much cheaper! And the posts are already there too. I would have done that if I had seen your post earlier. Oh well...
Kim
