February 2026
Like Tree4Likes
Old 06-29-2016, 06:01 AM
427 Street's Avatar
Cobra Make, Engine: ERA #472, Previous owner of ERA #677 427, ERA 289 FIA-USRRC Street
Default FIA Tire Size
I'm buying new tires for #2049. It currently has 295/50-15 (rear) and 235/60-15 (front).
I have the rears already, but what is ideal for the front?
235/60-15....current set up
235/65-15....fill the well up a bit more?
Something else?
"Some things get meaner as they get older."
Old 06-29-2016, 06:33 AM
The difference in diameter is almost +1". That means the car will have to be lowered in the front ~1/2" and you will lose 1" at the top of the tire. Do you have the clearance?
Old 06-29-2016, 07:46 AM
427 Street's Avatar
Bob,
I'll post a picture I have...it will be later today after work. Thanks
Old 06-29-2016, 07:58 AM
I would go with what you have now in regards to sizing. Your car appears to sit "just right" to me. FIA cars do have a different stance/tire to fender clearance than a street 427.
Old 06-29-2016, 08:10 AM
427 Street's Avatar
I doesn't even look like Avon does a 235...
225/60-15 or 225/65-15
Old 06-29-2016, 08:22 AM
427 Street's Avatar
Good point, thank you. So they have more of a rake...bit higher in the back?
Old 06-29-2016, 11:16 AM
DanEC's Avatar
I'm really outside the norm in that I went with 215/70-15 on the front and 255/60-15 on the back. Both are a just shy of 27 inches tall and fill the wheel wells fairly well. I had to shave the rear of the left front wheel lip down at the rocker slightly to get the front ones to clear.
Tires and Wheels
ERA 782 Running
Old 06-29-2016, 11:38 AM
1985 CCX's Avatar
I run the Power cushion up front, small yet tall. G7 in the rears.
Well balanced but not the best for track.
Old 06-29-2016, 02:44 PM
fastd's Avatar
So we are talking AVONs right?
I believe it's 225/65/15 for the front - that's what I had up there before I switched to MT's recently; no 235 size; I hear that people have gotten away with 245s in the front but some or all have clearance issues.
btw, the MT S/Rs I got for the front fit better than the Avons: 26x10x15s fill the wheel-wells better and sit a bit lower.
Old 06-29-2016, 02:46 PM
fastd's Avatar
is 2049 the blue one (with no stripe out of CT)?
Old 06-29-2016, 09:42 PM
427 Street's Avatar
That's the car...
Old 06-30-2016, 05:56 AM
The latter. See Tire selection
Old 06-30-2016, 07:35 AM
427 Street's Avatar
That answered my question Bob...perfect. Thank you.
Old 07-12-2016, 07:54 PM
427 Street's Avatar
Well, not the best picture....just a quick one with my phone.
Avons installed...
Front: 225/65-15
Rear: 295/50-15
This is the same set-up I had on my 427 street car. Thanks again to Nick Acton.
fastd and 66gtk like this.
Old 07-12-2016, 09:51 PM
Karl Bebout's Avatar
I'm happy with my 10.26.15 fronts and 12.26.15s in the rear. My FIA has a little bit of a nose-up attitude, veddy British-ish.
Karlos
Old 07-13-2016, 12:36 PM
fastd's Avatar
427 Street
Looks so good...
Old 12-28-2016, 07:45 PM
Avons installed...
Front: 225/65-15
Rear: 295/50-15
With the sizes you run, how is the balance. Our application is for an FIA MK2.
Mark
Old 12-29-2016, 03:00 AM
BJ's Snake's Avatar
Default Tyres
Running 245/60/15 on front, 295/50/15 rear Avons on this FIA build.
289 FIA Cobras RULE!
Old 12-29-2016, 05:45 AM
1795's Avatar
Thanks for that information. I am trying to figure out which tires to run on my 289 FIA SPF/Riverside Racer. The racing organization that I will run with is specific about tires and sizes. I am going to go with Hoosier Street TD's and the sizes that I am allowed are: 225/60/15, 245/60/15, 275/60/15, 25.5/8.5/15 or 26.5/9.5/15
I am a little concerned about having adequate clearance, and also wanting to make sure that I have adequate rubber on the track. 245 seems way to small for the back, especially given that the 289 will have approximately 450HP at the flywheel.
Any thoughts? I am starting to lean towards 25.5/8.5/15 in the front and 26.5/95/15 in the rear, as they are a little less tall and slightly wider. that will help lower my center of gravity a little and increase grip. The car has transverse leaf springs, so lowering height means placing lowering blocks over the leaf springs.
Old 12-29-2016, 09:33 AM
peterpjb's Avatar
in the main european historic races e.g. lemans classic and tour auto the tires are limited to front 215/70R15 and rear 245/60R15 (avon cr6zz)
