Like Tree8Likes
  • 1 Post By dacobb
  • 1 Post By redmt
  • 1 Post By Dwight
  • 1 Post By cobrakiwi
  • 1 Post By CarGuy427
  • 1 Post By DanEC
  • 2 Post By patrickt
Old 04-22-2017, 03:14 PM
dacobb's Avatar
Cobra Make, Engine: ERA 3018 - Lykins 289 H.O. SBF
Default Hey engine tranny gurus
Looking at who to build the engine.
Keith Craft, Engine Factory get good reviews.
Peter gave me a couple of names.
350 HP, 350 Torque, plus or minus. This is a street car with narrow tires.
Like 205-70-15 or 215-65-15.
Rear end 3.54.
Overdrive at .64 (I think.)
What do you seasoned veterans think about this?
CraftEngines likes this.
Old 04-22-2017, 05:46 PM
I wouldn't look any further than Brent lykins. He's a 1 man shop. There's no "production line" . 1 guy, 1 builder, 1 engine.
dcdoug likes this.
Old 04-22-2017, 06:48 PM
Dwight's Avatar
Smile
I've been to Keith Craft's shop five or six times picking up motors. He four or five guys building motors. Each specializes in a motor. He has a lot of equipment to CNC heads, etc.
Love his motors! 482, 461, 347, 408. We had great luck with all his motors. And when we had a small problem, he fix it!
Dwight
Old 04-22-2017, 07:03 PM
cobrakiwi's Avatar
We have had very nice engines from Keith Craft in the past.
Old 04-23-2017, 05:19 AM
Cobra Make, Engine: ERA 427 FE Shelby aluminum block, dual quads on Dove high rise, 5speed Tremec
Thumbs up Hey engine tranny gurus
Keith Craft hands down. Owner, Lance, is responsive and very thorough. Just finished an engine and shipped to ERA this past week. Cost is reasonable and impressive horsepower on dyno results. Good reputation and always responsive. Just a nice guy too. Answers all your questions and stands behind his work. Impressive engine machines in his shop. The latest technology. Recommend him. Good luck.
Old 04-23-2017, 10:16 AM
Jim Holden's Avatar
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
If you haven't purchased your transmission yet, consider TKO 600 with .80 fifth. I have both a .64 ( in my slabside with a 3.77 rear) and .80 (in my FIA with 3.31 rear) The .80 is more progressive and does not drop the revs like the .64.
Old 04-23-2017, 03:32 PM
DanEC's Avatar
Either one of these guys (Craft and Blykins) can build you an excellent engine. I used Craft but then they were just 90 miles down the highway from me.
ERA 782 Running
Old 04-23-2017, 04:55 PM
Murky781's Avatar
Cobra Make, Engine: ERA 781, 69' 428CJ, PPG BLACK. ERA 3005 Arctic White 331 SBF
Neutral
If ERA is doing the build, I've had great luck with Joe Lapine at Danbury Competitive Engines. The guy is a Ford genius, great prices and has a quick turnaround. Both my 428CJ and 337 came out of his shop @550hp and 409hp respectively. Happy to talk about my experiences with him if you want more info.
We make 3 bad decisions a day. Choose them wisely.
Old 04-24-2017, 03:05 AM
I'd be happy to give you a quote. Is there a certain look that you're going for? All cast iron? Cast iron block with aluminum heads? Any specific displacement?
I have engines across 3 continents, including engines in Malta, Australia, New Zealand, Canada, France, the UK, and others. My engines come with a 1 year warranty.
I know that I'm taking a slight risk in posting this publicly, as it would be easy for someone else to pop in here and say, "I can beat that price", but to be frank, if they need the business that bad, then that's ok with me.
Here's what I can offer:
*Ford 302 block, pressure tested, magnafluxed, steel abrated, bored/honed with torque plates, align honed with ARP main bolts, square decked.
*Duplicolor ceramic engine paint
*Brass freeze plugs
*Durabond camshaft bearings
*New cam thrust plate
*Felpro rear main seal
*Clevite main bearings
*Scat 9000 series crankshaft, 3.250" stroke
*Custom Comp Cams hydraulic flat tappet camshaft
*Cloyes timing set
*New Ford pump eccentric
*Racetec forged pistons
*Mahle piston rings
*Scat I-beam rods
*Clevite rod bearings
*Externally balanced rotating assembly
*New timing cover and pointer
*Felpro timing cover gasket
*Pioneer harmonic balancer
*Melling oil pump and shaft
*Front sump oil pan and pickup
*Stainless steel fastener kit
*New water pump
*Felpro head gaskets
*Dart Iron Eagle cast iron cylinder heads
*Crower lifters
*Trend custom pushrods
*Edelbrock Performer RPM intake
*Mr. Gasket intake gasket
*Comp Cams roller rocker arms
*MSD distributor with black cap
*Felpro valve cover gaskets
*Cobra valve covers
*Factory style alternator bracket and pulleys
*MSD coil
*Quick Fuel carburetor
*New water neck
*Valve cover breathers
*Carter fuel pump
*Autolite spark plugs
*MSD plug wires
*Wix oil filter
*100A 1-wire alternator
*Powermaster starter
*Engine assembled and dyno'd
*RAM billet steel flywheel
*RAM pilot bearing
*RAM HDX clutch kit
*Tremec TKO 600
*Quicktime bellhousing
*New clutch fork
$12999
This is a complete, ready to drop-in engine, including all fuel lines, plug wires, alternator, belt, etc. You are looking at a little over your 350hp/350lb-ft goal, but it will be very streetable and run on 87 octane. The engine as quoted would have a factory 289 appearance.
The .64 OD trans would be fine at this level. The overall engine demeanor would be mild, so the problems that occur with the typical "performance cam" and the .64 OD would not be present.
Let me know if I can be of any more help.
Old 04-24-2017, 08:22 AM
dcdoug's Avatar
+1 for Brent. He's helped me out and a bunch of others on this forum numerous times.
www.partskeeper.com
Old 04-24-2017, 08:26 AM
1795's Avatar
That is a very reasonable deal. Brent has an outstanding reputation.
Old 04-24-2017, 09:05 AM
I would have no qualms whatsoever in sending Brent a check based on nothing more than a telephonic "handshake." Our Cobra hobby in general is fraught with crooks, scammers, wannabees, and charlatans... but Brent ain't one of them.
dcdoug and redmt like this.
Old 04-24-2017, 12:05 PM
1985 CCX's Avatar
If you choose to go 4spd, Mike Miles has always done me right.
414-690-2748
Old 04-25-2017, 09:12 AM
Cobra Make, Engine: Backdraft
We would be happy to help you with your build. Feel free to give Tony or myself a call at your convenience to discuss options and pricing. There are many options for these engines and we can go over any ideas or questions you may have.
Lance Smith
Old 05-06-2017, 02:17 PM
dacobb's Avatar
*Brass freeze plugs
*Cloyes timing set
*Mahle piston rings
*Scat I-beam rods
*New water pump
*Crower lifters
*Cobra valve covers
*MSD coil
*New water neck
*Carter fuel pump
*MSD plug wires
*Wix oil filter
*RAM pilot bearing
*RAM HDX clutch kit
*Tremec TKO 600
*New clutch fork
$12999
Thanks Brent I'll reach out to you shortly.
Old 05-06-2017, 02:18 PM
dacobb's Avatar
Lance Smith
Thanks Lance will call you.
