Old 10-28-2018, 11:41 AM
RockBit's Avatar
Default Intermittent Horn with Ignition Off
While working in the garage where my Cobra is, I occasionally hear a low, short sound from the horn. This is with the key off. It doesn’t do it very often, but it is definitely there. Everything on the car works perfectly.
What could be causing this?
Chris
Old 10-28-2018, 02:19 PM
I've never seen a relay go flaky this way, so I'd suspect the horn switch/button (Lucas!) on the dash. Disconnect both the #11 wires from the switch and see whether the condition stops. Also, follow the pink wire from the switch to make sure that it's not being pinched somewhere.
Old 10-28-2018, 02:21 PM
Cobra Make, Engine: TBD
By any chance did you name the car Christine?
Old 10-28-2018, 06:28 PM
RockBit's Avatar
Thanks Bob. I’ll check it out and report my findings.
Chris
Old 10-29-2018, 05:05 AM
Ron61's Avatar
If the sound is so low it may be doing it when you are driving and you just can't hear it. That sounds as if it is getting a low voltage feed from somewhere. If the switch is good then check the hot lead to your horn and look for some place it may be touching a wire that is hot all the time just enough to let some voltage through. A relay sticking would normally let the full voltage through but that is another easy thing to check so don't ignore it.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 11-10-2018, 01:07 PM
RockBit's Avatar
I have only heard this one more time after spending many hours in the garage. At this point I am going to wait until it gets more frequent before trying to find the problem.
Thanks to all for the suggestions.
Chris
Old 11-11-2018, 10:21 AM
Cobra Make, Engine: ERA#375, FE 428, 1966 block, built by Jim Coleman Racing Engines, Stratford, CT
IMO, Ron61 is spot on.
The circuit is rather simple.
Positive -> Horn Button Switch -> Horn Relay -> LOAD (Horns) -> Ground Negative
Either the Horn Switch is bad and making an ON condition in the circuit
OR
the wire from the Horn Switch to the Horn Relay and then to the LOAD (horns) is somehow intermittently touching some other positive wire causing the horns to sound briefly.
I would start with the Horn Switch.
I would remove the Horn Switch and test it with an Ohm setting on your Multimeter.
This Horn Switch is not very expensive if it is like mine. (a small push button on the dash).
So you may want to just get a new one and replace that switch.
It also could be a flaky Horn Relay? and/or the wire from the relay to the horns (33 Violet).
ERA 375 - former Clubcobra ID REDSC400
TESLA P90D is my daily driver
