November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree12Likes
  #21 (permalink)
Old 12-13-2018, 02:49 PM
Ivygreen65's Avatar
Originally Posted by LMH View Post
Going strictly by the cap color and how it appears on my monitor, this does look pretty close. Good find!
LT BLUE HAMMER FINISH AEROSOL HAMMERED FINISH AEROSOL CAN
Check your local Ace Hardware. My local store has this in stock for $9.99 a can.
  #22 (permalink)
Old 12-18-2018, 05:38 PM
dacobb's Avatar
Cobra Make, Engine: ERA 3018 - Lykins 289 H.O. SBF
So the Rust Oleum light blue paint is too light.
Purchased the Blue Hammerite and will see if that's a better color.
LMH likes this.
  #23 (permalink)
Old 12-24-2018, 04:00 PM
dacobb's Avatar
So I cleaned, sanded and painted the body today, using the Hammerite light blue paint.
The match was nearly perfect, The paint can cap is a bit darker than the actual paint.
  #24 (permalink)
Old 12-24-2018, 08:16 PM
LMH's Avatar
LMH LMH is offline
Looks good!
Alba gu brąth
  #25 (permalink)
Old 12-25-2018, 07:37 AM
dacobb's Avatar
So here it is all cleaned up.
I might polish the tube later on, but it looks pretty good now.
LMH likes this.
  #26 (permalink)
Old 12-25-2018, 09:35 AM
Cobra Make, Engine: ERA#375, FE 428, 1966 block, built by Jim Coleman Racing Engines, Stratford, CT
What brand clips are you going to use to mount the Tecalemit?
ERA 375 - former Clubcobra ID REDSC400
TESLA P90D is my daily driver
  #27 (permalink)
Old 12-25-2018, 05:25 PM
Here's a tip to really set it off, polishing the tube makes it look really nice, one thing you could of done was mask off the BRASS collar that crimps down the end of the gun, then polish the BRASS, that's how I always restored the ones that I did, AND from my memory, it wasn't painted, but is was left "natural"
  #28 (permalink)
Old 12-25-2018, 07:18 PM
dacobb's Avatar
Acton has a set made in England (according to them) that is an accurate reproduction.
  #29 (permalink)
Old 12-25-2018, 07:21 PM
dacobb's Avatar
Hmmm...taking a look at that collar, it is embedded into the pleats. Unless that collar comes off easily, trying to do that in place on this particular gun would be pretty difficult. Would be easy to do on a gun that isn't pleated at the top.
So, does the collar come off? If so I will do that. And I will be polishing the tube at some point.
  #30 (permalink)
Old 12-26-2018, 08:31 AM
Dan Case's Avatar
Original Shelby Owner
The brass bushings in both main body designs were fixed in place and both were painted by the manufacturer. Paint doesn't stick all that well to brass.
Dan Case
  #31 (permalink)
Old 12-26-2018, 11:02 AM
dacobb's Avatar
I looked at the bushing pretty close and it looks like it's pressed in there. It tapers out slightly above the pleats, doesn't look easy to knock out without damaging the top of the body.
I'll leave well enough alone, but it would look kinda cool if the paint could be easily removed from the brass.
  #32 (permalink)
Old 12-26-2018, 05:33 PM
As I said, to my recollection , the BRASS wasn't painted, of course maybe mine on my car was just worn off. I've restored at least 20 of them, and left the Brass natural and polished. The trick is to do it BEFORE you paint the gun, masking if off TAKES time and dedication.
Perfection of one's work in restoring maybe anal, but excellent work is always rewarded.
How to accomplish it now, Q-tips, and Wal Mart Carb Cleaner, lots of patience, (short version) or strip it down, mask it up carefully, and paint again. There really is no time limit on restoring something the way you'd like it to be.
  #33 (permalink)
Old 12-26-2018, 07:25 PM
dacobb's Avatar
I lack both patience and a jewelers talent.
  #34 (permalink)
Old 12-26-2018, 08:09 PM
LMH's Avatar
LMH LMH is offline
Now you'll have to move on to countless hours of searching eBay for Elora 100 wrenches, a Shelley jack, BDS pliers, Thor hammer, bleeder tool that you can't buy, making a tool bag and spending huge amounts of hard earned dollars on a screwdriver.... all to put together an accurate tool kit just for display!
dacobb likes this.
Alba gu brąth
  #35 (permalink)
Old 12-26-2018, 09:34 PM
Beautiful
  #36 (permalink)
Old 12-27-2018, 07:20 AM
jolsen42's Avatar
Larry, you take anal to a whole new level.
John O
LMH and dacobb like this.
jjo42
  #37 (permalink)
Old 12-27-2018, 08:55 AM
https://www.webmd.com/mental-health/...ive-disorder#1
  #38 (permalink)
Old 12-27-2018, 08:58 AM
LMH's Avatar
LMH LMH is offline
You guys have no idea! When I started studying original bolt heads, I knew I was addicted!
Actually, it’s all Dans fault!
dacobb likes this.
Alba gu brąth
  #39 (permalink)
Old 12-27-2018, 10:17 AM
dacobb's Avatar
Well, I was looking into a tool kit. That's a whole 'nother level of redic.
Annnnnd...I just bought my first wrench on ebay UK!!!
Larry, can you provide the specs for that kit, including the bag.
  #40 (permalink)
Old 12-27-2018, 10:21 AM
dacobb's Avatar
Acton has the brake bleeder. ;>)
