Old 12-15-2018, 06:35 AM
Default Ignition Resistor
Hi We have a ERA #560 in our shop w/427 side oiler with MSD Ignition 6AL box. My question is where would the resistor for the ignition be located? We traced all the wires from the box through the firewall to the distributor back to the Ing switch etc and can't find anything that resembles a firewall resistor. Do all cars have them?
Thanks...
Old 12-15-2018, 06:44 AM
Texasdoc's Avatar
No. Most cars with the msd boxes do not run ballast resistors. You want the full voltage going to the coil.
Old 12-15-2018, 06:46 AM
Default Ignition resistor
Beautiful, Thank you.....
Old 12-15-2018, 12:12 PM
cycleguy55's Avatar
In the trash can.
Brian
Old 12-16-2018, 04:02 AM
Gaz64's Avatar
Your MSD is CDI.
450v plus goes to the coil primary, so the orange on the coil positive is NOT 12v ignition supply, hence NO resistor.
Be careful around that orange wire, that 450v gives a nasty zap.
Old 12-16-2018, 12:12 PM
RockBit's Avatar
Originally Posted by Gaz64 View Post
Your MSD is CDI.
You are not kidding. I did a spark test on mine once and saw the nastiest spark ever jump about 3 inches to the intake manifold.
Chris
Old 12-16-2018, 01:58 PM
Gaz64's Avatar
I'm talking about the primary side, orange and black wires, 450-550v depending on the model.
Secondary is much higher voltage but less current.
