Like Tree1Likes
  • 1 Post By DanEC
Old 04-27-2019, 06:23 PM
Default Heat insulation
The heat insulation on the foot box was destroyed by a rat. I need to replace it . Does anyone know where I can find some without writing on it.
Old 04-28-2019, 05:08 AM
DanEC's Avatar
Wow - wonder what else that rat chewed on. ERA has been (still is I guess) using Frost King duct work insulation that is inexpensive and can be found at Lowes or Home Depot most of the time. It has a gray mastic base about 1/8 to 3/16 inch thick, aluminum face and self adhesive backing.
66gtk likes this.
ERA 782 Running
Old 04-28-2019, 06:00 AM
Ron61's Avatar
I used Thermo Tech on mine and was very happy with it. It is easy to use and I had it right next to the headers and it never had any problem. I used it in the transmission tunnel, on the firewall, and on all brake and fuel lines that were anywhere near a heat source. When it got dirty I just used a damp rag and wiped it off. It is kind of expensive but was worth it to me as I put it on in 1997 and it is still there and working as well as ever. If you want to check it out here is the link to their website.
https://www.thermotec.com/
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 04-28-2019, 06:49 AM
Dwight's Avatar
Smile
Kilmat 80 mil 36 sqft Car Sound Deadening Mat, Butyl Automotive Sound Deadener, Audio Noise Insulation and dampening
$60 delivered
I have bought four boxes in the last 3 months. Finished a 68 Fastback Mustang and working on a Cobra.
I have used Hushmat and Dyno Mat several times in the past.
KilMat is just as good in everyway. And a lot cheaper. Lot cheaper!
https://www.ebay.com/itm/253546026761?ul_noapp=true
Old 04-28-2019, 03:23 PM
RockBit's Avatar
Cobra Make, Engine: ERA #812 427/482 FE
I had ERA use this product from Pegasus on the engine side of the footboxes instead of their usual material
https://www.pegasusautoracing.com/pr...p?Product=1828
I also have their heat shields and Easy-Cool insulation under the carpet. My footboxes are not hot.
Chris
Old 05-04-2019, 12:29 AM
Thank you for your input.
