October 2025
26 27 28 29 30 31
Like Tree1Likes
  • 1 Post By DanEC
Old 05-20-2020, 09:18 AM
DanEC's Avatar
Default Panicky - clutch pedal set screw
Patrick - at your suggestion I finally got around to checking the left side clutch pedal shaft boss set screw and it was a bit loose and needed some tightening (1-1/2 to 2 turns. Mine (#782) however has a cap screw that goes all the way through the shaft and both walls of the boss which would seem unlikely to come completely out. For some reason I thought I remember it was a point bearing set screw on your car that you had trouble with It coming disengaged - or am I mistaken?
bingo2 likes this.
ERA 782 Running
Old 05-20-2020, 09:28 AM
This is the set screw that came loose 12 years ago. Here is a pic of how the splined shaft came off once the set screw backed out. Is this the set screw of which you speak? ERA has another set screw that is holding the clutch pedal on the shaft right below the driver's feet. The drawings from ERA show that it is of the identical design, meaning just going down in to a milled portion of the splines just like the pic below. If either of those two set screws on your car go all the way through the shaft (meaning the set screw is at least an inch long) then there has been an undocumented modification by the boys at ERA....
Old 05-20-2020, 09:36 AM
This is that second set screw that is below the driver's feet.
Old 05-20-2020, 09:55 AM
Here's a sharper pic of the set screw that came loose on that first pic up above.
Old 05-20-2020, 10:23 AM
DanEC's Avatar
iPad spell check kicked in on title - didn’t catch it. I locktited the right side one years ago. It’s the left side one I never had checked. Looks like Era redesigned the left side attachment for a thru-bolted connection in-between our cars.
ERA 782 Running
Old 05-20-2020, 10:30 AM
So does yours look more like this drawing from ERA? If so, I think I might know why....
Old 05-20-2020, 12:57 PM
DanEC's Avatar
I would say that drawing reflects my car. I don’t think the left side (outer side) is splined anymore.
ERA 782 Running
Old 05-20-2020, 01:01 PM
Alright, next time I have my brake box off I'll take apart the shaft see what exactly it matches as to ERA drawings. I do remember that I had Doug do custom work to the pedal assembly because my feet are extra large (12EEE). The pedals are spread apart more as well as having the clutch pedal positioned farther back because of my long legs. I had completely forgotten that until now.
Old 05-20-2020, 01:16 PM
DanEC's Avatar
My pedals are spread too - I think even more than yours. I was able to pull up the floor mat and reach a finger down along the pedal arm and feel the top of the cap screw. I used a small light and mirror to look down in there to verify what I was touching. Then it was just a hit and miss process of finding the correct Allen wrench that fit. Wish I had made a note of the size but I hit on it pretty quick.
ERA 782 Running
Old 05-20-2020, 03:27 PM
DanEC's Avatar
Still a good tip to check that cap screw. Without splines (or so I think) if that cap screw we’re to back out and loose bearing on the far side of the shaft boss, the shear capacity of that connection would be halved and might shear through the screw on the other end with a heavy clutch or foot.
ERA 782 Running
