1Likes
Post By DanEC
12-23-2020, 03:14 PM
Registered User
Cobra Make, Engine: 289 ERA
Rear Diff
I have ERA3001 which is I believe their first 289 street car. It has a 289 w/a Galaxie T10 4-speed and what I think is a 3.xx Jag rear. My issue is that 1st gear is difficult to start out in as it's very high. The first time I drove it I thought I was in 3rd. My question is will installing a 3.5x or lower rear alleviate much of this issue or do I need to look at the gearbox instead? I believe the current ratio is a 3.07 or 3.31.
Any help would be greatly appreciated. Thanks!
12-23-2020, 03:30 PM
IN
From your comments I would suspect a 373 would be good for you.
12-23-2020, 03:48 PM
Can you measure your rear tyre rolling diameter?
Can you verify what diff ratio you have now?
We need to know more before giving a recommendation on gear ratio selection.
I would have a Richmond 5 speed or Tremec TKZ 5 speed with 3.73s.
12-23-2020, 04:25 PM
If your car is lazy in first gear with a 3.07 or a 3.31 first gear, the problem is not your transmission, the problem is your engine's low speed torque. Something is wrong with the tune or with the build. You should be able to light up the tires at virtually any engine speed above idle with a transmission first gear like either of those — irrespective of your rear end ratio.
Ed
p.s. I don't believe any T-10 had a 3.07 or a 3.31 first gear so I am going to believe you are speaking to a ring and pinion. Commercially available T-10 first gear ratios would look like 3.42, 2.88, 2.64 or 2.43. None of those first gears would have any problem with a 3.07 or a 3.31 rear end gear ratio. This brings me back to tuning and/or build.
There was also a 2.20 (or thereabouts) close ratio gear set. If you managed to get a 2.20 first gear and a 3.07 ring and pinion with an aluminum flywheel you might have difficulty. The short way home is to put in a steel wheel.
Reason: Spelling and Grammar
12-24-2020, 01:40 PM
CO
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
Something around 3.5 would be a good compromise, I believe my fathers original 289 Cobra had a 3.5 gear. If you have a lightweight flywheel it can make starts from a stop difficult with a tall rear end gear.
12-24-2020, 02:26 PM
BC
T5 trans
Hi,
I would go to a 1990 mustang T5 trans with 3.35 1st gear ratio. Your trans probably has a 2.24 to 2.64 1st gear ratio and is way too high for a small block and you would have overdrive if you wanted to cruise 75 mph down the hwy.
Perry
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
12-24-2020, 04:14 PM
Are you sure you weren't actually in 3rd? When I first got my ERA running I started out a bunch of times in 3rd until I got the feel of the reversed lever shifter down. However a 289 car has a more conventional shifter handle. Haven't done it in a long time now.
12-25-2020, 06:45 AM
OH
I’m guessing you have a close ratio unit, 2.36 first gear. Found this out- Ford used a 2.73 first gear in the Falcon, Comet and Mustang models, and a 2.36 first gear in their larger cars and the Shelbys
Well, if you’re satisfied how 4th gear is set up, you could switch to a wide ratio toploader, 2.78 first.
Like stated above, similarly, if you determine your t10 is a close ratio, you could swap out to a wide ratio unit.
Also like stated above, you could switch out the tranny for a 5 speed, ?t5/tremec, which has a lower 1st gear, and now overdrive.
Finally, if you are ok with the engine running a little higher in 4th, you could swap steeper gears in the rear.
And the option of swapping both the tranny and rear gears, which obviously would be the most expensive.
12-25-2020, 08:33 AM
I don't have any details beyond the original basic kit invoice. The car was built by Chuck Gutke of Cobra Restorers (Kennesaw, GA). He passed away several years ago. I believe that his wife Sandra continues the business, so there's a small chance that she has more information.
12-25-2020, 09:26 AM
SC
I'm betting you are starting in 3rd gear.
Bill S.
12-25-2020, 10:07 AM
Me too. Try starting off down in second and see if that's easier. If it is, then you're definitely starting off in third.
