Like Tree3Likes
  • 2 Post By patrickt
  • 1 Post By patrickt
Old 05-30-2021, 12:37 PM
Default Enabling Headlight "Flash to Pass" in 10 Minutes or Less
Have you ever just wanted to flash your headlights, but without having to turn the Lucas dash switch on and off? You know, just by tapping the little switch on the back of the turn signal stalk so that you can signal somebody with your headlights. Most of our other cars have this ability, and we used to call it "flash to pass" functionality and it was built in to the headlight dimmer switch, but not our ERA cars. So, is it hard to add this nice little touch? Will it require a massive amount of rewiring? Of course not. In fact, only one wire.
The pic below is of the VW signal relay on our ERA cars. ERA wires them so that terminal 30 and terminal 56 are connected. Both terminals are energized when you turn the Lucas dash switch on. If instead you have terminal 30 ALWAYS ENERGIZED and leave terminal 56 to be energized when you turn the Lucas dash switch on, then you will enable the "flash to pass" functionality that is actually built in to the VW relay. The relay is really a beautiful little component; a latching relay with flashing functionality. Wonderful. Now, if you would like to just "test out" what enabling "flash to pass" is like, pull the wire off terminal 56 as you see in my pic, then turn the Lucas switch on as if you were turning the headlights on (the headlights will not be on because you have pulled the feed wire off). You can now test out with the stalk control switch how nice it is to be able to flash your headlights without having to turn on the Lucas dash switch. Just put the wire back on when you're done testing.
To enable FTP permanently, just pull the lead off terminal 30, tape that wire off, and run an always HOT lead to that terminal. That's it. Maybe a 10 minute job. Yep, that's the way it should have been wired to begin with, IMO. But Bob P. did such a wonderful job on the wiring that I can't really complain. So, there's your ten minute upgrade... thank you very much.
rads42 and eschaider like this.
Old 05-30-2021, 02:20 PM
eschaider's Avatar
Very nice detective work there, Patrick.
Ed
Old 05-30-2021, 04:40 PM
Gaz64's Avatar
Ed
Good work.
Poor design if 30 is not connected to battery.
All the heavy current is still going through the headlight switch.
Old 05-30-2021, 04:43 PM
Originally Posted by Gaz64 View Post
Good work.
I eliminated that flaw previously in this thread: Headlight Wiring Upgrade I wouldn't trust even 10 amps going through a Lucas toggle switch.
Old 05-30-2021, 05:03 PM
Gaz64's Avatar
Yes, I know you already did that Pat.
Old 05-30-2021, 05:20 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
Where's ERA_Chas when you need him?
rodneym
Old 05-31-2021, 05:10 AM
I will consider making that change. I have to worry about legality. In some states, it used to be headlights couldn't be used without the rear parking lights. Now that daytime front running lights are common, the laws may be more flexible.
Old 05-31-2021, 05:18 AM
Originally Posted by strictlypersonl View Post
I will consider making that change. I have to worry about legality...
No worries; I know thousands of really good lawyers.
Old 06-05-2021, 01:01 PM
As per a request, here is a pic of my actual completed wiring mod. Any time I modify Bob's wiring I like to use an unusual color and I affix a label to the wire explaining what it is. One day, someone else will be under the dash and that fella will appreciate the fact that I labeled it for him. Note that I used a beautiful shade of purple for the feed wire. That wire leads over to the BROWN wire that goes to the Lucas light switch. Maybe an eight inch run. That's a really easy, convenient source of always on power and it makes intuitive sense to feed the FTP relay function with the same power line that feeds the light switch. I really love this mod. I now flash my lights at everybody.
rads42 likes this.
Old 06-08-2021, 07:04 AM
sd427's Avatar
Cobra Make, Engine: CSX4000 427 center oiler
Flash to Pass can also be used to trigger a garage door opener remote.
Old 07-09-2021, 11:39 PM
Cobra Make, Engine: ERA 427sc
Thanks for this tip! Worked out great.
QR code on the tag links back to this thread.
Old 07-10-2021, 04:57 AM
That's a nice job. And it only took me 15 years to stumble on that.
Old 07-30-2021, 04:02 PM
sd427's Avatar
Nice tip. Running a wire from the Lucas headlight switch did the trick on my CSX4000.
Old 07-30-2021, 10:05 PM
sd427's Avatar
Here is the kit to use the flash of your headlights to open a garage door.
RinkuHaus - Home Control Systems
