Like Tree3Likes
  • 1 Post By 1985 CCX
  • 1 Post By Grubby
  • 1 Post By mrmustang
Old 08-31-2022, 09:14 PM
Neutral
Default Watts Linkage
Has anyone ever installed one on an ERA?
RUMs are like a woman in Stiletto heals, you know they are going to put you in the poor house, but that has never stop anyone from pursuing one.
Old 09-01-2022, 04:16 AM
DanEC's Avatar
Watts suspension linkage is usually associated with a live rear axle (no IRS). ERAs use an IRS, either Jag based or a custom ERA designed IRS with a differential mounted to a cage which is bolted to the frame. Maybe someone has converted an ERA to a live rear axle for drag racing but I’ve not seen it.
ERA 782 Running
Old 09-01-2022, 05:49 AM
cobrarkc's Avatar
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
That is not necessarily true, Contemporary Cobras have a Watts set up for the Jag rear.
Acton Enterprises sells this conversion.
https://www.actoncustom.com/products...r-contemporary
Cobrarich
Old 09-01-2022, 08:22 AM
1985 CCX's Avatar
Skip the source in NH. (unless you like to waste time and money)
Best served to order the ERA outboard brakes unit and do it right. Doing it cheap always come back on you.
The outboard unit solves all your misgivings of the std unit.
Sargie likes this.
Old 09-01-2022, 10:16 AM
Grubby's Avatar
Cobra Make, Engine: ERA 838
ERA uses a trailing arm and Watts linkage wouldn’t work.
John
1985 CCX likes this.
Old 09-01-2022, 12:23 PM
mrmustang's Avatar
Gold Star Contributor
I've had several of my ERA's on the track, it's true, the ERA designed rear is better for the track than the standard Jag donor rear setup. However, if you are not planning to race your car, I see no reason to add a watts link type of rear end to the car.
Bill S.
Old 09-01-2022, 05:45 PM
DanEC's Avatar
An ERA rear suspension set up is different than Contemporary’s suspension setup. An ERA has radius or trailing arms to locate the outboard hubs which a stock Contemporary suspension lacks and that kit is intended to fix that. Not needed on an ERA.
ERA 782 Running
Old 09-02-2022, 09:31 AM
Cobra Make, Engine: Unique FIA
I had an early ERA (Jag rear). Sticky 335/35 17 tires with a built 482FE resulted in severe axle hop and limited ability to apply power early out of turns. I believe the problem was that the top of the jag hub was not very well located and would try and rotate around the big lower arm when subjected to high hp with good traction. Installing a watts link to the top of the hub solved those problems by stopping all horizontal movement at the top of the hub. For my car, it was a great solution.
