Old 09-13-2022, 03:45 PM
Cobra Make, Engine: Era #634
Default Speed Bleeders
Guys I am going to be changing the brake fluid out in 634. It has Sierra fronts and the Jag inboards. Does anyone happen to know what speed bleeders I need to order! There is a ton of them to choose from. Any help would be appreciated. Thanks.
Old 09-13-2022, 06:29 PM
Cobra Make, Engine: SPF832, 466cid
Motive Power Bleeder. The adapter is something you'll need to research based on ERA's master cylinder.
Old 09-14-2022, 06:41 AM
Sargie's Avatar
Cobra Make, Engine: ERA FIA 2045, FFR 4068 Coupe sold, FFR 1816 roadster sold, FFR 3218 Roadster sold
I 2nd the Motive bleeder. If you have Girling reservoirs power bleeder won’t work. Cans can’t handle being pressurized. Even just a pound or two and they blow up.
Old 09-14-2022, 07:48 AM
DanEC's Avatar
Go to post 30 in this old thread of mine. I believe the 3/8-24 are correct for the rear girdling. I have no idea for the Sierras.
Best approach to bleeding the brakes
ERA 782 Running
Old 09-14-2022, 10:51 AM
Cobra Make, Engine: Contemporary Classic Cobra CCX-3-3967
I have a Contemporary with the Girling calipers. I used this kit:
https://mossmotors.com/remote-bleeder-hoses
Old 09-14-2022, 02:38 PM
cycleguy55's Avatar
According to this page the speed bleeders for GMC Sierra front calipers are M10-1.5 X 33mm:
https://shop.advanceautoparts.com/fi...crew,484-152.1)
Brian
Old 09-14-2022, 02:56 PM
No, the "Sierras" are really big front brakes that were made by the Sierra company. I have them on my car but I still bleed the brakes the same way I have for 50 years. It is not the GMC Sierra.
Old 09-14-2022, 04:12 PM
Old 09-14-2022, 04:19 PM
cycleguy55's Avatar
Dayamn. And Ford U.K. made a Sierra. Details matter. E.R.A., of course, uses GM calipers - but apparently not the ones from pickup trucks?
I can't find any listings for Sierra, other than brake pads. Are they no longer in business?
Brian
Old 09-14-2022, 04:23 PM
They are no longer in business. I think they started out as JFZ, which got eaten up by Sierra, which then went out of business. But, the Wilwood Rebuild Kit #130-2655 fits them, just in case anybody cares.
Old 09-14-2022, 04:25 PM
cycleguy55's Avatar
Got it.
As far as the speed bleeders are concerned, I guess the OP will have to pull the bleeders, measure the thread size and pitch and go from there.
Brian
Old 09-14-2022, 04:29 PM
I'm going to just shoot from the hip and bet that the speed bleeders that fit the Wilwood #120-11136 also fit the Sierras.
Old 09-14-2022, 04:32 PM
Speed Bleeder Brake Bleeder Screws (1/4"x28, Set/4), fits Wilwood Calipers
Code: SB1428
Old 09-14-2022, 04:34 PM
Or maybe... Wilwood Brakes 220-0627 Brake Bleeder Screw For Use With Wilwood Calipers; 1/8 Inch-27 Thread Size; Set Of 4.
which look to be the same...
WILWOOD 220-0627 Brake Bleed Kit Calipers w/ 1/8-27 Bushing & 1/4-28 Screws 4pk
Old 09-14-2022, 05:34 PM
I do not have Girling cans. So the pressure should not be an issue. Maybe Peter P. can get me the thread size. Btw is thread size all I need? Does the length matter much?
Old 09-14-2022, 06:57 PM
Well you know you use a 1/4" bleeder wrench on them, so I don't see how it could be anything other than the SB1428. Here's a pic and chart of all your choices: Speed Bleeder Main Page
Old 09-15-2022, 11:59 AM
1985 CCX's Avatar
I prefer Speed-Pad-Change......... SPC
Old 09-15-2022, 05:09 PM
Got it.
Yes, it's not unusual for calipers to have the bleeder hole drilled larger and tapped accordingly for a larger bleeder screw. Part of the re-build process, where the original screw is seized in and likley broken off. This is what I've got with my GM calipers. One bleed screw is larger than the other one.
