Like Tree1Likes
  • 1 Post By patrickt
Old 08-18-2023, 04:56 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Default 838 Corner Balance
I weighed and corner balanced 838 a few days ago. Turned out great.
I did it with the tools and top in the trunk, like it is driven most of the time.
For those that think the 427 cars are nose heavy - you are wrong. The car is heavier in the rear.
Old 08-18-2023, 05:09 PM
Pretty close to mine:
Left Front (703) Right Front (667)
Left Rear (756) Right Rear (725)
Cross Weights 1423 & 1428 - 50%
Left Weight Percentage 1459 - 51%
Rear Weight Percentage 1481 - 52%
Total Weight 2851
Grubby likes this.
Old 08-18-2023, 07:42 PM
wolf k's Avatar
Cobra Make, Engine: Sold ERA FIA 2139, 331 Weber IDF
Here's mine, small block FIA
Old 08-19-2023, 08:35 AM
Grubby's Avatar
Even more rear bias than the 427 cars. I didn’t expect that.
Old 08-19-2023, 10:37 AM
Now you take your tire temps when you come off the track and they will tell you what adjustments to make to the suspension.....
Morris
Old 08-20-2023, 05:14 AM
DanEC's Avatar
John, do you have an aluminum block or an iron block? I was guessing at the weight of my all iron FE (except intake) #782 as 2800 lbs but I’m probably a little over 2900, maybe close to 3000 from what’s being posted here.
ERA 782 Running
Old 08-20-2023, 05:22 PM
Grubby's Avatar
BBM iron block and aluminum heads. TKX trans.
Old 08-20-2023, 09:23 PM
Cobra Make, Engine: ERA 427
These measurements seem to indicate that it would be better to have the battery mounted in the front on the right side of the engine compartment like the street cars had.
BD
Old 08-21-2023, 09:23 AM
Grubby's Avatar
Agreed.
Old 08-25-2023, 06:41 AM
DanEC's Avatar
I’m probably around 2900 total then. Sort of hard to believe the little thing is about as heavy as a V-8 65 - 66 Mustang.
ERA 782 Running
