Like Tree2Likes
  • 1 Post By
  • 1 Post By DanEC
Old 08-22-2023, 01:51 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Default Ammeter Shunt wire / No charge
838 is complete and I am doing some things that improve the car.
I installed an Ammeter shunt wire to protect the system. It is a 12 gauge wire run from the protected side of circuit breaker, that is near the starter solenoid, to the powered side of fuse 1. Fuse 1 runs the cooling fans. This basically connects the two sides of the Ammeter gauge.
With the shunt wire installed the Ammeter reacts like I would expect. The needle swings much less than without. It is easy to see the difference with the engine off and load applied.
The problem is, it will not charge. It will stay in a slight discharge. I don't see how this could impact the voltage regulator.
I would like to have the shunt wire, but normal charging is important.
Old 08-22-2023, 02:42 PM
Well, you can't rely on your eyes on this one, you have to test and take measurements. Let me just make a wild guess and say that the resistance on your new shunt wire is wayyyyyyy less than the resistance in the wire that is running through your ammeter. If that's the case then most of the current, regardless of which way it's flowing, is going through that wire and a much smaller, but proportionate, amount is running through your original wire. To test that out, and with the car engine OFF, turn on your lights and your fans, both pushers and pullers, that's 30+ amps flowing out of the battery. How far to the minus sign has your ammeter needle moved from the straight up position?
Old 08-22-2023, 04:16 PM
Grubby's Avatar
Patrick,
Fans and head lights on; approximately 30 amps with the shunt removed and approximately 10 amps with the shunt attached.
On a short road trip with the shunt installed. The ammeter stayed in a very small discharge for 40 miles (a few amps). I stopped and unhooked one end and the ammeter went the 40+ amps for several minutes. That tells me the battery was really discharging. I didn't have a voltmeter with me to check.
Old 08-22-2023, 04:19 PM
OK, 12 gauge wire running to the powered side of the #1 fuse. That's exactly how I have mine. If putting a voltmeter on your battery shows you're getting about 14.5 volts when revving to 2000 RPM then you're definitely charging. If your ammeter shows you're not charging then either the ammeter is not working right or current is not flowing properly in that wire in that direction.
Old 08-22-2023, 04:37 PM
And the charging light is not lit... ok put a voltmeter on the battery with the engine running at 2000 RPM and confirm your getting 14+ volts. If you are, and your ammeter is still showing a discharge then we'll need to put an inductive ammeter around both lines, and the fat brown wire that leads to the bottom of the circuit breaker from the solenoid, to measure the current in each. The current in the fat brown wire will equal the sum of the original ammeter wire and your new shunt wire (that's Kirchhoff’s Law). The difference in the two will be in proportion to the resistance of the two. What you are looking for is to make sure there's no unusual amount of resistance in your ammeter wire.
Old 08-22-2023, 05:34 PM
So let's say that we measure the current going through the two parallel lines (the 12 gauge shunt wire and the 10 gauge ammeter wire) on a 30 amp load, or a 30 amp charge, which will occur right after starting your car after a couple of long cranks, and 25 amps are going through your shunt wire and 5 amps are going through your ammeter wire. That would tell us there is too much resistance in your ammeter wire. That could be from a bad connection, a faulty wire or the ammeter itself. If you then put a short wire with two alligator clips across your ammeter and the two current values even out then that would tell you the resistance is in the gauge itself. Now, OTOH, if just putting a shunt wire across completely stops the charging circuit, but doesn't illuminate the idiot light in the process, then on that I'd have to noodle.
Old 08-23-2023, 04:44 AM
The shunt has nothing to do with charging function. If it's not charging, there is a problem elsewhere. For testing, see the troubleshooting section in my Wiring Primer:
https://erareplicas.com/427man/wiring/wprimer.pdf
Old 08-23-2023, 05:55 AM
DanEC's Avatar
I installed the shunt on #782 and it functions/charges fine. I originally had charging issues with my car but it appeared to be an issue with the red light indicator circuit not being able to excite the alternator to charge. I believe Bob provided a resister to increase resistance in the circuit - but I’m too dumb on electrical stuff to swear that’s an accurate description. But sounds like you think your car is charging normally w/o the shunt?
ERA 782 Running
Old 08-23-2023, 11:14 AM
Grubby's Avatar
Answer found.
Look at the attached photo. The ammeter on the Right is engine off and I also pulled the battery disconnect and it stayed like this. The ammeter on the Left is engine idling. Since the needle is showing ~5amp discharge when it is really 0 and ~2.5amp discharge when it is really charging, I have a gauge that isn't zeroed correctly.
In addition, the system is charging per my trusty Fluke (14.8v running). I also checked battery voltage engine off at 12.6v, then went for a 30 mile run with lights and cooling fans running. Upon return voltage was still 12.6v.
The gauge needle is shifted to the discharge range. I don't think it was like that when I completed the car.
The shunt works as it should. I guess I will monitor the ammeter and replace if it gets worse.
Thanks Patrick, Bob and Dan for the advice.
Old 08-23-2023, 11:49 AM
Yep, you can't trust your eyes on this one -- and a LUCAS ammeter is worse than a Smiths. I think you will find that you've reduced your current by a good 50% to 60% going through the ammeter. An inductive ammeter tool is really wonderful to have on your work shelf -- you really ought to put that on your Christmas list.
Old 08-23-2023, 12:32 PM
DanEC's Avatar
The ammeter shunt is a great modification. I would go for a drive and pull up to a light for a minute and out of the corner of my eye see the gage flick all the way left momentarily and my heart would skip a beat and then a few seconds later I would remember oh yeah, that’s my cooling fan kicking on. With the shunt it’s just a small flicker, kind of like a turn signal flashing.
Grubby likes this.
ERA 782 Running
Old 08-23-2023, 03:14 PM
Grubby's Avatar
I think the shunt is a good idea to. 60's cars have been known to have issues from ammeter shorts.
This is a good safety upgrade.
Old 08-23-2023, 06:24 PM
DanEC's Avatar
Yes, I have a 66 and 67 Plymouth with nearly full amps run through a cheap, factory amp gage. Too many of them have succumbed to electrical fires over the years.
ERA 782 Running
Old 08-24-2023, 05:25 AM
I haven't taken one apart, but I suspect that all ammeters have an internal shunt. The coil that works the needle only needs milliamps. My external shunt just adds to what's internal.
Old 08-24-2023, 10:46 AM
Cobra Make, Engine: ERA 427
When I sit at a traffic light with the turn signals on waiting for the light to change my Lucas ammeter rocks back and forth keeping time with the turn signal!
