Old 03-25-2002, 08:48 PM
Default Hosers, not the Canadians
Hey Mr. Putnam,
What kind of hoses do you use for your flex-lines for the standard brakes. If you use rubber, would it be worth it to upgrade to braided stainless for pedal feel?
While on the topic of hoses. Does your kit come with the hoses needed to run fuel lines and what-not through the engine compartment. If you do not include them, would you recommend the standard aeroquip type braided stainless or their new socketless hoses? Thanks in advance for all of your information.
2500 Pounds of steel, rubber, and fire. AAAHHHH!
Old 03-26-2002, 04:15 AM
Ike,
The kit comes with all the lines, hard and soft, out to the front calipers and the rear subframe. We use standard Bendix flex lines, which seem to work fine in our turnkeys. There's probably just a small advantage to using aftermarket stainless-shielded lines, which we use with our optional 12" rotor/Sierra brake update.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
