Old 06-19-2002, 01:47 PM
pk pk is offline
Cobra Make, Engine: Kirkham or the Evil Empire. Do kids NEED college?
Default battery behind seat
Bob-
Has ERA ever built a car with the battery behind the pass. seat.
Do you make a part for putting the batteries here?
I guess one could try a Kirkham tray, if you don't. Do you think that would work?
"thinking about a S/C suddenly" PK
Old 06-19-2002, 03:51 PM
We don't have much room behind the seats, unfortunately. It would take a very narrow battery to fit. When we do a rear-mounted battery, we mount it on the shelf above the rear suspension.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
Old 06-19-2002, 04:06 PM
Cobra Make, Engine: ERA Cobra #273, 427 S/O, ERA GT-40 #2057, Excalibur Cobra.
PK,
AS BOB SAID. THE SHELF ABOVE THE REAR SUSPENSION. IT WORKS GREAT. IT LOOKS GREAT.
KEEP THINKING "ERA". YOU CAN'T GO WRONG.
Y'ALL HAVE A REALLY GREAT DAY,
BLACKJACK
It's impossible to make anything FOOLPROOF - - Because FOOLS are so ingenious.
Old 06-19-2002, 04:28 PM
pk pk is offline
Bob-
I was thinking of dual motorcycle batteries. I would think the ERA has about the same space behind the seats as the Kirkhams and SAIs. In all the photos I've seen (with the batt behind the seat) you can see the pass. seat is farther forward then the drivers.
Blackjack-
ERA always been on the short list. The cars just look and sit right.
but look who I'm telling...
Good luck with your GT-40 cooling issue. I'm jealous as hell 2 cobras and a 40 you're my hero.
PK
Old 06-20-2002, 05:50 AM
DougD's Avatar
Cobra Make, Engine: Sold my beloved Shelby CSX 4068, Gessford 427 Ford
pk
I used a pair of Optima 6-volt batteries wired in series. They're about half the width of a standard 12-volt. Had to narrow the tray to fit the batteries and fab some special cables to make it work.
DougD
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
Old 06-20-2002, 07:40 PM
Cobra Make, Engine: ERA 427SC FMS 351W
Default Picture & Req'd Hardware to mount over rear suspension
Bob, can you post a picture showing exactly where ERA mounts the battery in the 427SC? Mine of course is mounted above the gas tank in the middle of the trunk which takes up a lot of useable space. This was done by original builder or PO.
Additionally, what mounting hardware is needed and how do you route the battery cables?
Old 06-21-2002, 04:22 AM
We make a panel to hide everything, including a nice secret storage area. A non-vented battery (we use Optima) is required. I think the cable is routed along the inside of the chassis rail, but I'm not sure.
This car has the battery cutoff switch on the panel, on the right.
Bob Putnam
-E.R.A.-
Old 06-21-2002, 09:40 AM
pk pk is offline
I think I'll probably end up hiding it behind the new alum. trunk panels with nut-serts. I was just asking if ERA makes an optional tray for putting the batteries where I've seen them in the Kirkhams etc. I'm assuming this is were they were in the original S/Cs.
I've got to be carefull of "Evan-itis".
I'm going to keep repeating "It's only a car, It's only a car"
PK
Old 06-26-2002, 12:56 PM
PK,
EVAN-ITIS AIN'T ALL BAD. HE HAS A GORGEOUS CAR. ONE OF THE ABSOLUTELY NICEST I'VE EVER SEEN.
I LOOKED AT IT AT SPRING FLING AND HE IS USING TWO 6 VOLT OPTIMA BATTERIES IN SERIES BEHIND THE PASSENGER SEAT. THE CUT-OFF SWITCH IS MOUNTED TO A BRACKET WHICH IS ATTACHED TO THE SIDE PANEL.
PERHAPS WE CAN GET HIM TO POST A PICTURE OF IT. IT'S REALLY A COOL LOOKING INSTALLATION.
I'M NOT CERTAIN THAT IT'S "ORIGINAL" BUT IT IS ON EVANS CAR.
I'M CONSIDERING CHANGING MY INSTALLATION. IT WOULD GIVE ME MORE ROOM IN THE TRUNK AND MOST OF MY PASSENGERS HAVE NO PROBLEMS WITH LEG ROOM.
IF IT WORKS IN AN SAI IT SHOULD WORK IN AN ERA. BOB ???
Y'ALL HAVE A REALLY GREAT DAY.
BLACKJACK
Old 06-26-2002, 12:59 PM
PK,
BY THE WAY - IT'S NEVER "JUST A CAR".
BJ
Old 06-26-2002, 01:10 PM
pk pk is offline
Blackjack-
ya got me all wrong.
I love Evan's car. I saw it up close and personal about 3 months ago at the Snakepit open house. It's drop dead about the best looking cobra out there IMHO. (Gumball, Turk and that black ERA from Germany are right behind him) Equal parts pretty and mean. In fact as you said his car is the inspiration for me putting the bat. there and maybe putting the fuel pumps in the trunk.
I'm just saying we've all got to draw that line somewhere and I'm aware I could end up losing my mind over making my baby perfect.
pk
oh and I guess Evan settled it once and for all aluminum is faster then fiberglass.
Old 06-26-2002, 02:07 PM
PK,
I WAS NOT REFERRING TO EVAN'S CAR AS MUCH AS "EVAN-ITIS". HECK, I'VE GOT A BAD CASE OF IT MYSELF.
BESIDES - IF YOUR NORMAL YOU'RE GOING TO GO "NUTS" OVER SOMETHING - - - IT MIGHT AS WELL BE COBRAS.
I'M REALLY CONSIDERING THE BATTERY ISSUE "BUT" I'M NOT SO SURE THAT I WOULD WANT THE ELECTRIC FUEL PUMPS AND LINES IN MY TRUNK (ENCLOSED). THEY LOOK GREAT BUT I'VE JUST BECOME RATHER SHY ABOUT THINGS THAT GO "BANG". ONE LITTLE LEAK - THEN YOU STEP ON THE BREAKS OR TURN ON THE LIGHTS AND - - - - I DON'T WANT TO EVEN THINK ABOUT IT. IF YOU DO IT MAKE DARN SURE THAT YOU USE GOOD QUALITY HOSES AND FITTINGS AND RUN IT A LONG TIME WITH THE TRUNK OPEN TO CHECK FOR LEAKS. I WOULD ALSO LIFT THE TRUNK LID AND "SNIFF" BEFORE I CRANKED IT UP EACH TIME - - - JUST IN CASE.
Y'ALL HAVE A REALLY GREAT AND SAFE DAY,
BLACKJACK
Old 06-26-2002, 02:24 PM
pk pk is offline
I re-read your post and I took it wrong sorry.
You're right about "...it might as well be cobras"
It's what my wife says to her friends (and her "mother- in- law").
I'm real close to spending $500 on a custom saw blade to cut picture molding that matches the original molding in our apt. And I don't even get to keep the damn thing, the lumber yard does.
Of course my wife wants to just buy some that looks close. She says when you get your Cobra you can obsess over getting it perfect.
pk
