10-13-2002, 05:18 AM
Cobra Make, Engine: ERA 427SC FMS 351W
Softer Ride
Bob, I have 6 Carrera coil overs (with adjustable height collars) in my 427 SC with front and rear sway bars and 16 wheels (245/50s in front, 27X12-16 Sports Car Specials in back). I want to soften the ride, especially the front.
I would like to accomplish a bit softer ride with the same wheels / tires at this time. What is the softest spring dimension for the front and rear you would suggest for street driving?
The front springs are yellow not the red color that my FIA buddy received in his ERA kit. The rear are chromed. The car has the FMS crate 351W with aluminum heads.
10-13-2002, 05:54 AM
IL
Jeff
Mark Donahue
10-13-2002, 09:24 AM
Those tires are not helping things - try 22 psi front, 24 psi rear. Increase the pressures a bit if the car feels too sloppy.
Our standard springs for your combination would be 250 lb/in springs in front and 4x350 lb/in springs in the back. I hope your Carerra's are valved correctly for the springs...
Bob Putnam
- E.R.A.-
10-13-2002, 02:50 PM
IL
Bob:
All joking aside, how many small block 427 cars have you guys made? Any 429/460's ?
Jeff
Mark Donahue
10-14-2002, 04:09 AM
Jeff,
Since our engine stands on the chassis are the same with FE and SB, it's hard to say exactly. I'd guess that about 5%-10% of 427SCs have SB engines. I think we've done 3 or 4 429/460 engine stands in 650 chassis'. They don't fit very well, vertically - lots of restrictions on intake systems to clear the hood.
Bob Putnam
- E.R.A.-
10-14-2002, 07:05 AM
Cobra Make, Engine: ERA #122 (Sold) : Ford GT #484 Heritage Edition; 2008 GT500 Red/Black
I would be afraid of the resell on the vehicle...I know alot of people are really into the small blocks but I would think it could hurt things....Hey Bob don't forget the 427SOHC motor down here in Austin  Tight fit...
Matt
2006 Ford GT #484 Heritage Edition
2003 Hummer H1 OpenTop
2003 Hummer H1 Wagon
10-16-2002, 07:52 PM
Spring Specs?
Bob, thanks for the advice to use 250 lb/in in front and 4 springs in the rear at 350 lb/in. What is the free length and inside diameter of these springs? From the ERA manual I gather that the front spring is 2.5" inside diameter and a free length of 12" for an adjustable height coil over. 14" for non-adjustable set up.
The rears are stated to be upgraded XKE springs (350 versus 250 lb/in). But I am unsure of the free length and inside spring diameter.
Can you fill me in on the details? Does Eibach make these springs?
Thanks as always.
10-17-2002, 04:30 AM
The rear springs are 2.5" ID by 10" long with the non-height-adjustable dampers. We use 8" long springs with our rear height-adjustable dampers.
Bob Putnam
- E.R.A.-
10-17-2002, 07:09 PM
Info on Front Springs? please
Bob, how about the free length and inside diameter dimensions for the front springs WITH an adjustable height coil over? I believe this is where most of my opportunity is. Thanks
10-18-2002, 04:01 AM
"From the ERA manual I gather that the front spring is 2.5" inside diameter and a free length of 12" for an adjustable height coil over."
You answered your own question three replies above. Just follow the manual.
Bob Putnam
- E.R.A.-
