Old 01-17-2003, 01:25 AM
Rick Parker's Avatar
Default Headlight Relay Question
Bob: Could you tell me what is the Bosch part number for the headlight relay you use on your cars?
Thank You
Rick
Old 01-17-2003, 03:58 AM
The dimmer relay is a VW 111 935 227 D/H.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
Old 01-18-2003, 11:18 PM
Dominik's Avatar
Default I wish I had an ERA
bob,
2.5 hours to reply?
not bad bob, not bad ... ;-)
rick,
I tried to find your gallery. searched for your name found the last thread, found your profile, but no link to the gallery. (and my buttons give me a hard time as usual)
keep well,
dom
If I don't respond anymore, that's because I can't log in
Old 01-19-2003, 12:18 AM
Default What Flasher?
Thank you Bob. On page 5 of the wiring booklet are the headlight relay & flasher mounted next to each other on the bracket along with the fuses below? Can a #550 Flasher be utilized or is ther another number that is specific to the install? The one in the drawing appears to be square in lieu of the more traditional round can type?.
Thanks again for your assistance
Rick
Old 01-19-2003, 05:32 AM
Rick,
You can try another brand 3-pronged relay. They're pretty universal - but some work better than others with the relay board, that's all.
Bob Putnam
-E.R.A.-
Old 02-11-2003, 11:31 PM
Smile Headlight relay question??
Is there a plastic plug that can be used to mount and mate with the headlight relay? (5 wires) Or are the individual wires attached to it without utilizing a plug?
...........Rick
Thanks Bob ............You da' man
Old 02-12-2003, 03:55 AM
Rick,
Unfortunately, the only socket I know of is built into the VW fuse/relay module. About $100. Even we won't throw that much money away.
That's why we supply a harness and have a place to mount the relay on the trailer relay/flasher plate.
Bob Putnam
-E.R.A.-
Old 02-12-2003, 08:36 AM
cobrajeff's Avatar
Bob -
Can you please give me the part number and supplier of the "trailer relay" that you use?
Thanks,
Jeff Burgy
CobraJeff
ERA P 202
Old 02-12-2003, 10:22 AM
Jeff,
We buy the relays wholesale from Del City but you should be able to get something equally effective locally - from an auto supply or someone who services/rents trailers. It must be made to adapt a car with separate brake and turn signals to a trailer with a shared turn/signal filament.
Bob Putnam
-E.R.A.-
