Old 02-18-2003, 05:53 PM
Cobra Make, Engine: ERA #664 finally done!
Default differential question
I've located a open differential, my question is can i find new parts to make it limited slip or is it not worth the expense? It has 3.00 gears also. Thanks
Old 02-18-2003, 08:36 PM
ls1ac's Avatar
Call Reider Racing
800-517-1330
HAVING TOO MUCH FUN
Scott
Old 02-19-2003, 04:01 AM
Charlie,
We use Reider for all our differentials. They can add an LSD, and changing your ratio is pretty economical.
Bob Putnam
-E.R.A.-
Old 02-19-2003, 05:10 AM
Clois Harlan's Avatar
Bob,
Since most 90" wheelbase Cobras are basically configured the same what width of rearend do you use assuming an inside measurement from the inside backing plates. I am in the process of changing over to a 9" and really just want to check my measurements.
Clois
"Let's roll"
"Be part of Something Good
Old 02-19-2003, 08:07 AM
Clois,
Flange-to-flange distance depends on the wheel offset. I would start with a track dimension (ours is 57") and work backwards with wheel specs.
Bob Putnam
-E.R.A.-
