Old 09-07-2003, 10:02 PM
decooney's Avatar
Default Please ask your engine builder...
Hi Bob,
I was reading an older post you made on the 180 vs. 160 thermostat thread. Clearances, oiling, oil design, etc... Your points are well taken and I'm doing some re-evauation on this myself in regards to winter vs. summer driving temps. I have realized some interesting characteristics about my engine when running at 160 or 180 temps and especially the valvetrain and throttle response under loads. 20 degrees makes a big difference here to me, and I just keep thinking about the clearances and factors revolving around how these motors, parts, and oils were designed to run in the first place.
Question:
Can you confirm what thermostat your local engine builder is using on the FEs that go with your cars?. I may go back to a 180 for lots of reasons, but just thought I'd bounce it off you again just to see what they say or what you might have to add here. Thanks, Duane.
Duane
Old 09-08-2003, 04:18 AM
Duane,
We use a 180F thermostat in all our turnkeys. The small hole we drill for an air-bleed typically drops the temperature to 175F on the road.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
