Old 01-29-2004, 11:21 AM
joea's Avatar
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
Question Lakewood 15203 for Tremec
Does the Lakewood 15203 bellhousing for the Tremec use a 2 or 3 bolt starter flange?? I purchased a CVR Starter for Ford FE and it has a 2 bolt Flange is this correct? It is the bellhousing that determines this correct?
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
Old 01-29-2004, 12:08 PM
Well, for one thing, my Lakewood .pdf file says that bellhousing is for a T-5....so you might wanna check bellhousing depths, etc... before you go any further.
The block plate that it uses is a universal block plate...for several of their bellhousings. I have one on mine, and I also have the CVR starter....it is bolted on with 2 bolts. Mine's a SBF however...hey, wait a minute...that's a SBF bellhousing....you trying to use it with an FE?
Old 01-29-2004, 01:14 PM
joea's Avatar
My bad that was from the parts list for the FIA 289 car...here is the one for the 427 (FE motor)
Lakewood 15210
Old 01-29-2004, 01:37 PM
Unfortunately, my file doesn't say anything about that...plus it's a different block plate than the other engines. My guess is if your starter is a 2-bolt starter, then it should work.
