Old 02-10-2004, 05:37 AM
Todd Hedges's Avatar
Cobra Make, Engine: ERA 427SC w/428 & Richmond 5-speed Car 611.
Default 5 point belts
Does anyone at ERA have a lead on 5 point belts that work well with the original kit 4 point belts?
Is it required to replace the whole set up, or can the anti-sub belt be added to the others?
What special provisions have to be made to anchor the anti-sub belt?
Thank you
Todd
...."they say I'm crazy, but it takes all of my time."
Old 02-10-2004, 05:46 AM
Clois Harlan's Avatar
I could be wrong Todd but I am sure you can just add a Anti-Sub belt at anytime. I just bopught another one for my passenger seat a couple of weeks ago ($22.00).
Clois
"Let's roll"
"Be part of Something Good
Old 02-10-2004, 06:46 AM
Default 5th belt
Clois,
If you don't mind, where did you find the additional belt?
Old 02-10-2004, 07:37 AM
Todd,
Several of the speed shops here sell them individually. If you would like I will try and pick one or two up for you and mail them. However, I believe summit sells them seperately.
Todd I just called my speed shop and they run $13.99 ea and they have them in black and blue.
Clois
"Let's roll"
Old 02-10-2004, 07:39 AM
rdorman's Avatar
Renegade Nuns on Wheels
I have Deist 4 point harnesses and was able to by the sub straps, from Deist, to make them six point. They attach to the same point as the lap belt.
OhioCobraClub.com
LondonCobraShow.com
Old 02-10-2004, 07:45 AM
Clois,
Thanks, that's very generous of you.
I will take a look at Summit first.
Todd
Old 02-18-2004, 05:01 PM
Todd,
Are you set on going with 5 point? We were going to go with 5 point, until we realized that we would either have to find a seat with a hole in the cushion, or run the sub belt around the front of the seat (less than ideal). In addition to that, you would have to make an extra hole in the floor to mount the sub strap. With 6 point, you can avoid both situations. Either sub belt bolts to the same point as the lap belts and comes up and over the side of the seat. It's not much of a hassle, and is quite comfortable.
2500 Pounds of steel, rubber, and fire. AAAHHHH!
