| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
31 |
04-04-2004, 04:52 PM
IL
Cobra Make, Engine: E.R.A. 428FE Single carb.
Chicagoland ERA owners
I have just purchased an ERA basic kit and would like to hear from any builders in the Chicago area. I am in Plainfield, Il. This is the first car that I am attempting to build and would welcome any advice or tips that will help keep me out of trouble.
04-04-2004, 05:04 PM
TX
Cobra Make, Engine: ERA #122 (Sold) : Ford GT #484 Heritage Edition; 2008 GT500 Red/Black
Not in Chicago but the inlaws are in. You will love the kit...I would recommend that you ahve them paint it and do everything you can afford to...you will not be disappointed its really easy to work on.
Good luck.
Matt
2006 Ford GT #484 Heritage Edition
2003 Hummer H1 OpenTop
2003 Hummer H1 Wagon
04-04-2004, 05:54 PM
NJ
Cobra Make, Engine: ERA 389 427s/o
Ron,
What have you purchased that would be a "basic" kit from ERA?
Knowing that info would help direct you to people that can assist in the build.
Jamie
04-04-2004, 06:16 PM
IL
Jamie, Kit has frame, body, interior, wiring kit, radiator and fan, front suspension less brake rotors and calipers. The frame has been powder coated black and has fuel tank installed. I will need to purchase complete engine, trans and rear end and rear suspension along with tires and wheels.
Any suggestions on good source for FE engines would be helpful.
04-04-2004, 09:09 PM
Ron,get the rear from ERA also,It might save you alot of trouble in the long run.It is easy to install or have them do it,if you buy one used from someone else make sure its all done or you'll might spend as much chasing it with new parts.Its a great kit with great support and easy to build.Congrats
04-04-2004, 09:42 PM
KS
Cobra Make, Engine: ERA #664 finally done!
I did my own rearend, didn't save enough money to make it worth my time and my ring & pinion and LS were good. If i did it over I'd buy the ERA custom rearend. I haven't had time to tally up what my engine cost but if you have to piece one together and you're not building it yourself I'd check into Gessford or Southern Automotive building you one.
04-05-2004, 07:51 AM
TX
Buy the rear end. I would also think about having it done as a roller and painted by ERA. For the cost of their standard paint job you are going to be hard pressed to find someone in your area to do it for that cost.
Give Drew or Rob a call at Keith Craft Motorsports in Dallas for the engine. The just built a 527 Cu In stomper for an SPF owner in your area. I would suggest you call everyone and get prices from everyone for all the engines you might want. You can go NOS, New Guinesses Blocks or shelby blocks...cost will be a factor.
Good luck.
Matt
04-05-2004, 08:39 PM
IL
Guys, thanks for all the good advice. It is reasurring to know that there are people outhere like you that will offer to help with advice on the building process.
Ron.
04-05-2004, 09:36 PM
IN
Cobra Make, Engine: CSX4047 power by Gessford
Good luck...
I bought a CSX on a whim wanting to do what you are after.
Talk with George Anderson at Gesssford re a FE the man is honest and knows how to build a good big block.
Roland
