Old 06-23-2005, 02:36 PM
chuckbrandt's Avatar
Cobra Make, Engine: ERA # 665, 390 (to start with) Toploader
Default ERA Where to get switched power for anti-deiseling solenoid?
Hey Bob,
Where would be a good place for me to get switched power for an anti-dieseling solenoid I want to add to my carburetor?
Thanks, Chuck
Build website at www.chuckbrandt.com
Old 06-23-2005, 03:36 PM
Tap off the driver's side of the bottom fuse of the passenger's side fuse group. ("fuse 4") It's on when the ignition switch is on or in the accessory position.
If you want power only with the ignition switch on (but not on in the accessory direction), use the double wire that goes to the ballast resistor - #43 (white) on most cars.
Old 06-23-2005, 05:57 PM
Default Thanks!
Thanks so much!
Chuck
Old 07-03-2005, 04:20 AM
Default Balast Resistor wire worked great.
Thanks Bob,
Using the balast resistor wire worked great, I'm not using it because I have an MSD, and just hooked in to the thing I had joining them. So far it has worked great, and no more run-on.
Chuck
