Old 05-02-2006, 07:44 AM
Chaplin's Avatar
I am chassis 650!!
Replica is not a dirty word.
Old 05-02-2006, 07:54 AM
ERA 626's Avatar
I have not tested it in actual ft per stop but it is not a substantial differance.
at $479 it is a lot to spend for a minor upgrade. Sorry, but it sure looks good.
Old 05-02-2006, 10:16 AM
Chap'
Check to see whether your steering knuckles are castings or fabricated. The fabricated ones have intermediate bolt-on caliper brackets.
Old 05-02-2006, 10:28 AM
I've tracked my ERA (154) with the Camaro brakes and found them perfectly acceptable with adequate stopping power. A multi piston caliper generally gives you more control over 'impending lockup', thus you can modulate\control your braking to a greater degree.
If my calipers needed changing out I might consider something new, other wise, I'm good to go!
Old 05-02-2006, 10:55 AM
Chaplin's Avatar
Originally Posted by strictlypersonl
Chap'
I think they are castings- but will double check. Thanks.
