Old 05-02-2006, 04:57 PM
mtr mtr is offline
Cobra Make, Engine: ERA 719, 302 5speed
Default Auto Xing
When I get my car it will spend lots of time on track. I have 17" Kuhmo V700s coming for it and looking for suggestions on tire pressures and alignment specs. We have a fairly small SCCA region here so with a little luck and some good driving perhaps I could be in contention for TTOD.
Old 05-03-2006, 04:17 AM
Set the front suspension camber to -1/2 deg or -1 deg.
Zero front toe-in (or even a bit of toe-out) will help too, but willl make the car unstable in normal street driving. It's easy enough to adjust at an event though. 1/2 turn out on each tie rod. Mark them first so you can return them to the original position.
Set the rear camber at the maximum negative within the normal recommendations or maybe 1/4 deg more. More than that and you'll get uneven tire wear during normal driving. With the ERA rear, keep the toe at zero.
Stiffen up all the shocks by 2-4 clicks.
I'll let others give advice on the tire pressures.
