Old 05-04-2006, 07:30 PM
iwantacobra427's Avatar
Cobra Make, Engine: SOLD: ERA FIA #2114 with 331
Default Can I use a left rotor on the right side?
I got a good price for two left drilled/slotted rotors from JEGS. They claim the only difference between the left and right is the drilled pattern. I figure a FIA wheel will cover most of the pattern up and not be noticable...
Old 05-04-2006, 11:10 PM
Default They're unidirectional... Need to use a right one
on the right side..
Old 05-09-2006, 09:51 AM
REDSC400's Avatar
Send a message via AIM to REDSC400
Usually, the rotors internal air fins are set up to suck air in. If you mount the left on the right side, it will not impell the air thru the hollow part of the rotor. It will FIT, but the cooling would be wrong. ALso, be aware that drilled / slotted rotors can never be turned or trued by a rotor lathe. They are throw aways in that respect. As is typical of their racing heritage and intended use.
Art in CT
Old 05-09-2006, 12:05 PM
ZOERA-SC7XX's Avatar
If you'r not seriously racing it, the rotors should be fine...would only affect excessive temps under severe racing conditions. I'd use 'em on the street.
