Old 03-15-2007, 05:31 AM
Snakebit's Avatar
Default Wheel Paint
When I purchased my ERA FIA, I had you paint the centers of my Trigo wheels white. I need to paint them Whimbleton white to match the stripes. What brand and type of paint do you use to paint the wheels, enamel, polyurethane? I need to know so the new paint will be compatible when sprayed on the existing paint. Thanks, Snakebit ERA 2100
Snakebit
Old 08-31-2007, 05:03 PM
Kramer's Avatar
Cobra Make, Engine: ERA 739
Default Snakebit - Wheel paint?
just wondering what the answer was here as I get ready to paint my wheels?
Old 09-01-2007, 06:01 AM
Snakebit's Avatar
PPG Concept single stage Urethane enamel. Touched the bare aluminum casting where I sanded the rough edges wit PPG DPLF white epoxy primer. Used a Sata Minijet spray gun. They came out smooth as a baby's ass, no orange peel with a high gloss. ERA uses PPG paints
Snakebit
Old 09-02-2007, 06:25 AM
Kramer's Avatar
Thank you...if you don't mind, what did you use to rough up the current centers with?....and once you painted did you spray any clear afterwards?
Kramer
Old 09-02-2007, 09:15 AM
Snakebit's Avatar
If they are un painted just use 3M maroon scotchbrite pads. Use 3M fine line tape to mask off the wheels so you get a nice clean line. Shoot a good coat of PPG DPLF epoxy primer, let dry for 1/2 hour then shoot 2 coats of enamel. The PPG DCC Concept enamel is a single stage paint with a very high gloss, no need to clear. I polished the aluminum edge of the rims before I painted the wheels. I started with 220 grit , then 400, 600 800, 1000, 1500. then buff with rouge buffung compound and finish with white rouge. Polishing aluminum is very dirty work. That is why I recomend polishing before painting. If you slip with the buffing wheel there goes the paint.
Snakebit
Old 09-03-2007, 06:52 AM
Kramer's Avatar
Appreciated it Snakebit!!!!.....Ill get started in the next month.
