Old 10-17-2007, 06:26 AM
cobra's Avatar
Cobra Make, Engine: ERA 427 SC # 571, 472 Shelby aluminum "stroker " CSX # 299 from Gessford, 48 IDA Weber carburetors from Jim Inglese
Default Canton or other oil thermostats
I thought another time to install an oil thermostat in my ERA. Until now I used duke tape but the satisfactory with temperatures below 72° F isn't enough.
The car is equipped with the three Brake/clutch reservoir cans. For this reason I haven't a lot of space.
Who have mounted an oil thermostat on his car ?
Who can show me some pictures ?
Greetings from Switzerland
Walter
Walter
http://www.kreuchi-auto.ch
Old 10-17-2007, 06:52 AM
Originally Posted by cobra
Who has mounted an oil thermostat on his car ?
Who can show me some pictures?
Here's a shot of my Canton #15-820 with the oil temperature bulb going in the left rear of the pan (driver's side).
Old 10-17-2007, 07:47 AM
Banned
Walter, here is a pic of my engine bay. Toward the front you can see the install of my Canton thermostat. E-mail me through CC (click on my user ID) and I will send you some better close-ups.
-Dean
Old 10-17-2007, 10:09 AM
jwoodard's Avatar
Walter,
Here's a photo similar to Dean's with the Canton Oil Thermostat mounted.
Jim Woodard
Old 10-17-2007, 12:07 PM
Loadco's Avatar
Walter,
Take a look in my gallery. I have a canton thermostat in my ERA 427SC. There are several pictures there.
ERA #509
2003 Z06
Old 10-22-2007, 07:55 PM
Chaplin's Avatar
Dean, Jim or Loadco-
I have the same canton oil t-stat sitting on my shelf in the garage which I have not installed yet, but am going to in the next few weeks. However, I have a question for you.
Did you have to cut down the threads on the fitting that screws into the "out to oil cooler" hole? On my t-stat, it does not look like you can screw in a std fitting without the threads hittig the plunger that is inside the t-stat.
Also, Loadco, were you able to make the set up work using the existing oil lines on your ERA? If not, how much new oil line did you need and how many fittings- trying to figure out what I need to order.
Replica is not a dirty word.
Old 10-22-2007, 08:28 PM
JWheaton's Avatar
Cobra Make, Engine: ERA 389 427s/o
At least you hope to be doing that!
Old 10-22-2007, 08:33 PM
Chaplin's Avatar
You don't need an engine to have an oil t-stat!
Old 10-23-2007, 03:46 AM
Loadco's Avatar
Chaplin,
I used the fittings supplied from Canton to be able to adapt to AN fittings. To be honest I did not see a problem as you described but I doubt I really looked that close. I don't have any leaks so I guess all is OK. I had to make up new lines. Sorry I don't remember what I needed to purchase to make it work. My memory is not that good anymore.
ERA #509
2003 Z06
Old 10-23-2007, 03:56 AM
Naumoff's Avatar
Walter,
The Mocal is much more compact and you should be able to just intercept the lines as they go out to the cooler.
The Canton is a good unit but it is so big.
From what I understand the Mocal are used on Porsche's installed from the factory.
http://www.racerpartswholesale.com/mocal.htm
Old 10-23-2007, 04:21 AM
Chaplin's Avatar
Thanks Loadco- my t-stat did not come with any fittings from canton. I picke up some standard fittings and they look too long. Maybe I'll call Canton and see if they can send them to me.
Tony- that mocal unit opens at 180, which may not be hot enough. The canton opens at 215 I believe.
Old 10-23-2007, 08:37 AM
Banned
Chaplin, when I ordered my Canton unit from them I also ordered the -10AN fittings that they sold (assuming they worked with the unit, which they do).
-Dean
Old 10-23-2007, 09:14 AM
Loadco's Avatar
Chaplin,
The fittings from Canton install with an O-ring, they definatelty are not pipe thread.
ERA #509
2003 Z06
Old 10-23-2007, 10:13 AM
Old 10-23-2007, 10:29 AM
Chaplin's Avatar
Ok, here's the deal. I called Canton today and the fittings they sell for the unit have shorter threads than the std fittings that I bought from Summit (or wherever I got them). Their tech told me to just go ahead and cut mine down, so that is what I am going to do. And mine do have the o-ring seal as well.
Thanks for your help.
Rob- That is a sweet looking set up, and I like the fact that it can be turned on or off manually. I have been eyeing that unit for a while, but it aint cheap!
Old 10-23-2007, 03:39 PM
JAC's Avatar
JAC JAC is offline
Cobra Make, Engine: Classic Roadsters II
Cobra and cheap
"COBRA" Big kids gokart
Old 10-23-2007, 03:51 PM
Naumoff's Avatar
Chap,
180 is plenty hot enough.
If you push it the temp will go over 215 with no oil t-stat.
It is the cruising around with no load on the engine and winter that I want to get the oil temp up faster.
Old 10-23-2007, 05:55 PM
lineslinger's Avatar
Walter, this "sandwich" style thermostat is another option for a set up such as yours. The female/input of the thermostat threads are 1/2" NPT and the male side fittings (capped in this shot) I used are are 12AN.
Old 10-23-2007, 07:38 PM
Chaplin's Avatar
Tony-
With my old motor, even in peak summer weather with stop and go traffic and the occasional blast through country roads, I could never got the oil temp above 90C, which if my math is correct is about 195 F.
Old 10-24-2007, 04:03 AM
Naumoff's Avatar
If I do some brisk driving my oil temp will go to 100*C. This is also with my Aviad oil pan which takes the temp in a different local than my Canton pan did.
In the winter time is my biggest concern. and 180*F is fine.
It is alot better than the needle not moving.
