December 2025
Old 04-11-2008, 07:53 AM
Default Pad Replacement on Outboard Braked Rear
Bob, on my ERA outboard rear with the Camaro PBR calipers that have the integrated emergency brake, pictured below, does pad replacement require the tool that rotates the piston back in to the caliper when compressing, or will a simple tried and true C-clamp and block of wood suffice to compress the piston?
Old 04-11-2008, 05:36 PM
Blush... I don't know. I'll take a look at a caliper tomorrow morning. Maybe there's something obvious.
Old 04-11-2008, 06:43 PM
Thanks. Here's a typical caliper tool that winds back pistons in rear disc brake calipers with integral parking brakes. http://store.summitracing.com/partde...5&autoview=sku
Old 04-12-2008, 05:02 AM
Still ambiguous. There is a spot for a hex key in the middle of the piston but I'm not sure its function.
The caliper is very similar to the 88-94 Corvette, so that might help. I've Googled the subject to death though, even searching through the Corvette forum. If those guys can figure it out, it must not be too hard.
Old 04-12-2008, 07:17 AM
Well dang, I feel like I just played "Stump the Band" and won. Anyone else out there happen to have a 88-94 Corvette and changed out their rear pads? Or perhaps your brother-in-law is the service manager at the local Chevrolet dealer?
Bob, before you throw in the towel on this question do you think you could bounce it off Doug on Monday?
