Old 04-21-2008, 07:53 AM
Cobra Make, Engine: ERA FIA #2128
Default Oil Filter Placement on FIA
I'd prefer to keep my oil filter on the side of a 302 block as stock. However, I understand that if I do this it requires a short FRAM filter. Couple of questions:
Is this true?
Are there alternatives other than a remote oil filter setup? Such as an offset fitting that points the cooler down rather than straight out.
I really don't want to use the FRAM. If there are other manufacturers that will fit, please let me know that as well.
Thanks,
Doug
Old 04-21-2008, 08:42 AM
The Fram number is there because I've got a big Fram book with all the filter specs. Most places can cross-reference the number to their own brand.
I vaguely remember there was a Bronco block adapter that turned the filter 90 deg. toward the front, but I've never seen one on an ERA.
Old 04-21-2008, 08:59 PM
Ron Going's Avatar
Cobra Make, Engine: ERA FIA 2095, 331, w/ TKO 500
Doug, A WIX 51311 or a NAPA 1311 (both made by WIX) will fit nicely. Enjoy your car, they are great fun.
Old 04-21-2008, 09:23 PM
Rick Parker's Avatar
If you are not using a mechanical fuel pump Ford Racing offers an adapter that will turn the filter 90 degrees and lay it up next to the block & timing cover.
Page 116 of current Ford Racing catalog (which is online)
Rick
