Old 07-26-2008, 09:53 AM
iwantacobra427's Avatar
Cobra Make, Engine: SOLD: ERA FIA #2114 with 331
Default Harrison tank hose connections for FIA..
Can you tell me how to hook up the Harrison tank? I saw one connection depicted in the manual but not the other two. Also what size hose or part numbers did you use? Thanks.
Old 07-26-2008, 11:06 AM
Snakebit's Avatar
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
The hose on the bottom 3/4" goes to the water pump. The small hose on top of the tank goes to the radiator hose fitting on the passanger side. The hose fitting comming out the filler neck is the over flo line.
Snakebit
Old 07-26-2008, 11:36 AM
If you don't have a diagram on page 96 (or thereabouts...) in your manual, download the latest one. I put in better instructions a few months ago. PM me if you need the download location.
Old 07-26-2008, 12:45 PM
Default For the Harrison tank I think the #1 connection goes
to the brass fitting on the top passenger side of radiator. I'm not using a heater in the car. I don't know what to connect to #2 and #3 on the tank. For the water pump I think I connect the top one (bypass?) to the thermostat fitting at the intake manifold. Since I'm not using a heater don't I cap the bottom one? Or is that connected to #3 on the Harrison tank?
Old 07-26-2008, 06:06 PM
Rick Parker's Avatar
[IMG][/IMG]
The braided hose goes from the side of the tank to the top of the radiator. The other attaches from the bottom of the tank to one of the small outlets on the water pump, the tank then become the fill point. The other small outlet on the water pump is plugged.
Rick
Old 07-27-2008, 07:22 AM
I just added a few shots in my gallery of the Harrison Tank hook up on ERA #2117. Rick
Old 07-27-2008, 08:33 AM
Thanks guys! Those pictures help a lot!
