Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Factory Five Racing
Old 03-05-2005, 11:26 PM
Ant Ant is offline
Default Factory Five IRS axles?
I would appreciate information on the length of the half shafts used with CV joints in the Thunderbird IRS setup?
I phoned a reputable axle manufacturer he told me they were 15" long, me thinks thats is not correct, but if they were more like 11" - 12" then I could use them!
A J. Newton
The 1960's rocked!
Old 03-06-2005, 09:17 AM
John A. Simpson's Avatar
Cobra Make, Engine: KMP 393 $27 S.O. bored and stroked to 482
Did you try checking at the FFR forums, I'll bet someone there like Larry N Johnson would have the info you need.
FFCobra
Sideways
Old 03-06-2005, 09:31 AM
Ant Ant is offline
Default FFR Axles
Thanks John will do!
A J. Newton
The 1960's rocked!
Old 03-06-2005, 10:19 AM
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
Ant,
The Factory Five pin drive rear IRS T-Bird/Cougar 8.8" axles are 15", but are that length for the reason of the FFR rear suspension design. The pivot point of the CV joints relative to your rear arm/hub pick up suspension points and shocks are critical to the life and action of the joint.
Personal eMail to continue discussion.
grumpy
Old 09-29-2007, 06:10 PM
If I buy the IRS axles would it hurt my 1/8th and 1/4th mile times?
Old 10-22-2007, 10:19 AM
carbon777's Avatar
Cobra Make, Engine: Hurricane
The answer is .....It mostly has to do with your set-up.
Get adjustable shocks and a few set's of springs.
There are many Mustang Cobras with IRS running low 10's ..... in a 3800 lb cars too.
