10-29-2009, 04:49 PM
Chokes
How many of you run a functioning choke on your carb? Manual, engine heat or electric?
707 had a Holley with the disconnected choke plate tied open when I got it. The new BG carb has an electric-assist choke that I just got around to wiring... and then unwired and took the choke plate and bar off for the time being. I may just take the whole choke assembly off.
It seems to me that a choke is only for cars started and driven immediately in cold weather. Since we all warm our beasts up for at least a minute or two and drive gently until the oil temp starts to rise, the small convenience of a choke seems greatly outweighed by its general clutter and hassle.
Whatcha think?
10-29-2009, 04:57 PM
Whatcha think?
Yep, that gets my vote. Mill that air horn off too, while you're at it. I can't imagine that it fits in a turkey pan, though 707 may not have one.
Although the "choke folk" will be argue that chokes are a necessity.
10-29-2009, 05:09 PM
VIC
admittedly I live in a temperate zone but I've usually only need a choke on a car that is not in good tune.
and as you say - after a brief warm up its no issue
consequently a weight saving opportunity can be identified....
LoBelly
10-29-2009, 05:14 PM
Mo.
I kept mine functional....cable controlled, needed periodically in the midwest.
LoBelly, way to get after it.
10-29-2009, 05:33 PM
I'll probably keep the airhorn - it's not worth the effort to remove for cosmetic and *ahem* weight-reduction reasons. Maybe I'll decorate it every Xmas or something.
10-29-2009, 05:37 PM
Leave the horn, it fits fine, even with the air cleaner. But yank the choke.
10-29-2009, 06:16 PM
OR
Use a choke for what?  Totally personal preference for the street. I've run carbs with & without. A nice working choke is convenient but kinda ugly on a carb that gets a lotta "show time". My vote, because it's a Cobra.... No Choke!!!
ERA FIA 2088
10-29-2009, 07:42 PM
Cobra Make, Engine: AddVintage, 351C
A couple quick pumps on the gas pedal is all the choke I have ever used.
10-29-2009, 10:24 PM
Ca.
I also live in the midwest so i left the manuel choke on and hooked up.....
10-30-2009, 04:32 AM
No choke or air horns. Air horns 'n short air cleaners don't mix.
Too many toys?? never!
10-30-2009, 06:02 AM
Stolen Avitar
GA
Look at the apparent hand speed on LoBelly! Years of practice at work there gents.
Steve
PS as far as I'm concerned if the carb doesn't need a choke, then it doesn't need an airhorn either. Just one more way to smooth air entry. Dave's comment about short aircleaners is right on as well.
10-30-2009, 10:16 AM
The Holley HP series doesn't have them. So buy a new carb! Or, milling isn't that bad, even for someone like Patrick.
10-30-2009, 10:18 AM
I've been milling around for years.
10-30-2009, 10:22 AM
Yes, we know. Almost 10,000 "millings" just in this neighborhood.
High performance seldom used cars don't need chokes or airhorns. Push the gas pedal a couple times, bring the idle up for a couple minutes and your ready to go to supermarket.
10-30-2009, 10:31 AM
Well let me toss out another tidbit that you were undoubtedly unaware. "Milling around" actually serves a very useful purpose. If you are concerned that your cattle are going to stampede you can prevent it by moving them in a circle to help calm them down. Thus, "milling the cattle" tends to soothe their nerves. I'll add that to the "Stuff that RodKnock Doesn't Know List."
10-30-2009, 10:34 AM
I thought that was mulling??
10-30-2009, 10:40 AM
Cobra Make, Engine: SPF #1019
Gunner, I assume you bot a Road or Speed Demon...right? How come you didn't get the Mighty Demon? The later is very popular, tunable and comes without a choke.
10-30-2009, 10:50 AM
Holley HPs are Barry Grant wannabes - just compare the features. Wow, Holley discovers fuel sight windows after aeons! Look, machined metering plates! Wow!
Unless I missed something, though, you can't get an HP series with a vacuum secondary. EDIT: Oh, now I see the Street HPs. Still prefer BG.
Randy: If I'd wanted a mechanical secondary, I'd have gone with a Mighty Demon - mechanical, and no air horn, and no choke. Since I'm not going to live on the track or strip, I made the sensible choice of a vacuum model (and one of the easiest vacuum secondaries to tune, too).
Yes, undoubtedly, I'll need to know about "milling the cattle" being that I live in an area where cattle do dot the hills and when I do see them out "milling around", I tend to roll down the window of my car and yell "Mooooooo!"
10-30-2009, 10:53 AM
I do that when I'm passing the mall.
