February 2026
  #41 (permalink)
Old 11-20-2009, 05:18 PM
Gunner's Avatar
Originally Posted by rooster View Post
My car is in storage now but I have been fighting an off idle hesitation all summer. Trying to gather info for spring. My question is, What is "idle eze"? I've been playing with 4150"s for a long time and never heard that term until lately when reading several different forums.
Idle-Eze is a feature on newer Barry Grant carbs (can be retrofitted by changing the baseplate and doing some minor drilling on the carb body).
It's an air bleed valve in the center of the carb that does the same thing as drilling holes in the butterflies, but unlike drilling it's completely adjustable.
It didn't appear to do squat for me on my mild-cam engine, but it's a huge timesaver (and saves having to do things like replace butterflies if you get the holes too big) with cammier engines.
The reason you never heard of it is that Holley's ain't got it.
  #42 (permalink)
Old 11-20-2009, 05:21 PM
CC Member / Sponsor
Originally Posted by cdnus View Post
Tom,
So the result would be simular to changing the air bleeds?
No. It acts the same as changing the main jet but only on the idle and transition circuit.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
  #43 (permalink)
Old 11-20-2009, 05:31 PM
saltshaker
Sorry to hijack your thread, didn't mean to, just hard to miss the oportunity to discuss problems with a great bunch of guys.
Craig
  #44 (permalink)
Old 11-21-2009, 06:02 AM
Thanks, but now I'm confussed ! If I have to turn the idle adjustment screws out more then 1.5 turns to get the highest rpm at idle and this is wrong...what do you do? The difference between 1.5 turns and 2.5 is almost 100 rpm at idle and the motor idles around 800rpm w/ a comp 282s cam. so what's do I do next?
  #45 (permalink)
Old 11-21-2009, 11:01 AM
Gunner's Avatar
Normally, idle mix screws should not have to be turned out more than a turn and a half or so. It's possible your engine really needs that much fuel at idle, but in most setups it's an indication that something else is wrong.
Were the carbs new on this engine, or were they previously setup for another engine?
  #46 (permalink)
Old 11-21-2009, 08:55 PM
the carbs are new...#9776 holleys
interesting..the idle screws are now 2 turns out and when trying to start it pops out the back ( seconary carb) carb...not sure why that is.
Jon
  #47 (permalink)
Old 11-27-2009, 11:16 PM
CC Member / Sponsor
Backfiring out the carbs is a sign that the engine is too lean.
Cubic Performance
HiTech Legends
Evolve Lubricants
