12-08-2009, 04:35 PM
KS
Cobra Make, Engine: jbl
1966 ford 427 le mans race engine simulation dyno numbers
alright here are the numbers used and the power figures since there was lots of conversation on the 429/460 site. thought all of you might find this of interest, it is from eap computer simulation program of course. i'll try to make it readable.
4.24 bore x 3.78 stroke, 426.98cid
2.09" intake, 1.625 exhaust
compression 12.5 chamber volume 76.1
dual plane manifold, 1 780 cfm carb.
headers with open exhaust
solid flat camshaft intake 244 102 c/l, exhaust 244 102c/l, lash .025 both, rocker arm ratio 1.76, lobe seperation 102, gross valve lift .5 both,
primary exhaust pipe dia. 2.15", collector length 25"
pk tq 512 @ 5000, pk hp 510 @ 5500, avg tq 449, avg hp 364
10.8" idle vacuum
12-08-2009, 04:40 PM
If you do nothing but back the compression back down to the 10.25 that he said the engine has, what does that do to the numbers?
12-08-2009, 04:46 PM
KS
pk tq 489 @ 5000, pk hp 486 @ 5500 avg tq 428, avg hp 346
idle vacuum 8.3"
btw, both graphs climb real good to 3000rpms then dip real bad to 3500 and start climbing again.
12-08-2009, 04:49 PM
idle vacuum 8.3"
... and if you now run some mufflers, even the more forgiving ones? But not straight zoomies, it's got to be something realistic.
12-08-2009, 04:58 PM
Keep going and you'll be down to my idle vacuum.  And don't forget the bump for the super race gas.
12-08-2009, 05:13 PM
That's interesting. I pull over 13" at 850RPM. My cam is 245/245 @ .050.
12-08-2009, 05:43 PM
Well I was being a bit tongue-in-cheek (which can get you hurt around here.) It was about 7" when we had it backed down to 16* initial. At 20* initial, where Don Gould wanted it, 13". I am back to 18* initial because I couldn't get what I thought was the right curve using the MSD springs at 20* and its about 10" @ 900 rpm idle. 248/248 @ .050.
12-08-2009, 05:49 PM
I think your LSA is skinnier than mine, too. At 114 degrees for a LSA, my overlap is less, more vac, but it shaves off some of the overall power.
12-08-2009, 06:03 PM
Needs mufflers, air cleaner, water pump and alternator to be an apples-to-apples sim. Fan, too, for 60s tech. (When did electric fans become common?)
12-08-2009, 06:05 PM
You:
Me:
12-08-2009, 06:08 PM
294 seems awfully short for seat-to-seat. Are you sure that number isn't at a different number, like .01 or something?
12-08-2009, 06:14 PM
Wrong settings, fixed it.
12-08-2009, 06:17 PM
My overlap at .050 is only 17 degrees. It is 96 degrees at seat-to-seat.
12-08-2009, 06:23 PM
Mine at .050 is 28*.
12-08-2009, 06:27 PM
Yes, your four degrees, at the cam, less of lobe separation is pretty significant. The lobe durations are effectively the same, but you have a higher performance cam than mine. The next step up, back in the day, was the cam that DCDoug has (the "B" cam). As I recall, the LSA on that was 106 but still the same lift and duration that I have.
Reason: typo
12-08-2009, 06:29 PM
The next step up, back in the day, was the cam that DCDoug has (the "B" cam). As I recall, the LSA on that was 106.
Do you recall what the lift was on that B cam?
12-08-2009, 06:30 PM
Exactly the same as mine, same duration, same lift, but the LSA was moved down to 106.
12-08-2009, 06:33 PM
I had thought about that cam, but after talking to Keith and telling him I would likely move up to aluminum heads and the 2x4 at some not-too-distant point, he suggested the 294S. It idles good, and revs and pulls like dammit.
12-08-2009, 06:36 PM
I had thought about that cam...
Same here, but I thought the "B" would be a little more of a PITA on the street, although Doug swears he loves his. It's "8 toes out of 10" in to race mode.
EDIT - BTW, the Ford literature specs it as making its best power between 6000 and 7000 RPM.
12-08-2009, 06:48 PM
I can imagine the B is a gnarly cam. I am still being gentle on my engine, I think I have only been to the 6200 rev limiter 2 or 3 times, but the power from 4500-6200 in 3rd into 4th is what David Crosby calls "celestial."
