Old 03-25-2010, 06:04 AM
DanEC's Avatar
Default Difference in height between mid riser and low riser intake
Does anyone off-hand know the heigth difference between a low-riser and a mid-riser dual quad intake? I'm meaning the heigth of the carb mounting surface.
Dan
Old 03-25-2010, 03:47 PM
DanEC's Avatar
Does this quote out of my American Engine Data Book make sense?
"The intake ports for the MR measured 1.34 x 2.34 in. wihile the HR's ports were 1.34x2.72. Actually, the MR's port dimensions weren't anything really new, being the same as on the 1960-1962 HP 352 and 390 cid engines. The same heads were later used on the 1968 - 1970 428 CJ eninges but with smaller valves. The difference between these heads and all the others is that the MR heads used much larger valves, 2.195 in. intake and 1.73 in. exhaust."
So, it appears they are planning the use of a medium riser reproduction dual quad intake on my street Cobra engine with 390 HP heads - and I have a feeling it may not fit under the hood.
Old 03-25-2010, 06:10 PM
Cobra Make, Engine: ERA #766, FE V8, Toploader
Dan, I'm using a Blue Thunder medium riser 1 x 4bbl manifold on my FE. It was recommended by ERA for fit and for originality (has the firing order embossed on a manifold runner). I would imagine a medium riser 2 x 4bbl would fit as well, but ERA should know for sure.
Old 03-25-2010, 06:14 PM
Ignore the above--I hadn't yet seen your other thread when I wrote this.
