Old 05-18-2010, 10:21 AM
undy's Avatar
Default Dove Tunnel Wedge casting porosity issues & solutions.
As discussed in earlier posts my Tunnel Wedge on my KC 482 has coolant porosity issues. A weld/machining repair was conducted and there was/is still minor coolant leakage into the oil, although now in small amounts. A block sealant was added and it's seemed to stop 95% of the seeping. I finally got somewhat fed up and called Dove myself this AM. They introduced me to a patented process called "IMPREX". In layman's terms it's "Vacuum Casting Impregnation". The company that owns the process is called Godfrey & Wing Co., out of Ohio. I called them and talked to technical. They were very knowledgeable and helpful too. This is a standard process for aluminum castings. Their tech mentioned that they just received 4,000 aluminum engine blocks from GM for the process application. They have standing contracts with most of the major automotive MFRs. Rather than go into a bunch of technical verbiage I figured I'd just post their web site. Thoughts, points and counter-points would be greatly appreciated. Let me know what you think...
http://www.godfreywing.com/vacuum-casting-impregnation/
Too many toys?? never!
Old 05-18-2010, 12:00 PM
Dave,
Did they quote a price to treat your TW?
Chas.
Old 05-18-2010, 01:24 PM
cobrarkc's Avatar
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
Do you know if you can machine the piece after it has been treated? Like say you want to port match.
Cobrarich
Old 05-18-2010, 03:54 PM
undy's Avatar
Dave,
They said the minimum charge is $150 and that the manifold can easily be done within that amount.
You can machine afterwards, understanding that the area machined will not have the coating. I would heartily recommend machining THEN treatment though.
Old 05-18-2010, 04:03 PM
xlr8or's Avatar
How about Dove paying for it?? They made the faulty part.
Old 05-18-2010, 04:14 PM
undy's Avatar
I didn't buy it directly from them and it's been over a year anyway. The vendor I bought it from valiantly tried to repair it. Too much water's gone under the bridge to try to recoup $$ at this point. I really don't care about the money. I'm just wore out dealing with it. Dove's customer service really isn't stellar in the regard.
Old 05-18-2010, 04:53 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
I use to be a Manufacturing Engineer with Navistar (supplier of the Powerstroke to Ford), and that repair method was used from time to time for salvage of preproduction engine blocks and intake manifolds. It was not considered acceptable for production engines going to customers. There were concerns with long term sealing.
Good luck.
Old 05-18-2010, 05:08 PM
undy's Avatar
Good luck.
The guy I talked with at Godfrey & Wing seemed pretty sharp. He said that they would do 2 consecutive treatments. Evidently the process will accept some layer building. I'm going to attempt to limp through the summer and plan on doing the tear-down this winter. If things get worse I'll be forced into acting sooner. If the plan prevails then I'll have more time to research the process further. I'll look into the possibility of longevity issues also.
Old 05-18-2010, 05:29 PM
Too bad GM didn't know this before they sent over 4000 blocks for treatment...
Chas.
Old 05-18-2010, 05:37 PM
joyridin''s Avatar
Wanna bet they knew? LOL
Old 05-19-2010, 01:23 PM
Do you have to account for the coating when machining for tight tolerances? Or does it all get "absorbed" into the metal?
I'm thinking the press fit holes. Like when you get things chromed and they have to mask off those areas.
Old 05-19-2010, 03:20 PM
Grubby's Avatar
I was a GM manufacturing engineer for 15 years before Navistar. You can bet they know the risks.
Many times there is a balance between delivering something or delivering a good product.
In my opinion, Navistar made the right call. We only fixed pre-production type engines. They were run in test mules or on dynos and then scrapped. If there was a sealing failure, it did not hurt their reputation.
Old 05-19-2010, 06:06 PM
undy's Avatar
It sure looks like Chrysler and GM have some long term faith in it if they're using it in their production engines. Their site hosts a video of the Chrysler V6 aluminum blocks getting impregnated. Maybe the process has been improved?
