Old 07-06-2010, 09:18 AM
Originally Posted by cobred View Post
In the morning disable the ign. so it doesnt start and crank it over a dozen or so revolutions and then pull the plugs and see if any plugs are wet with coolant. Its worth a try.
Car was at 210 when we shut it off last night. He just cranked it a dozen times, pulled all 8 plugs and no sign of moisture.
Old 07-06-2010, 09:24 AM
If it was me, I would just jump to a head gasket replacement (both of them).
Old 07-06-2010, 09:28 AM
We already knew that.
Old 07-06-2010, 09:31 AM
Well, I thought about it last night. He obviously broke something else besides his bypass hose. I don't see how it would be his radiator, pump, or anything else since the pressure was immediately down and the fans were still blowing. I guess it could happen, but it seems unlikely. The only thing left are the gaskets and, in the worst case, warping the aluminum.
Old 07-06-2010, 09:34 AM
....which is why I came here to you experts before we started tearing into the engine.
Old 07-06-2010, 09:43 AM
Pressurize the cooling system to about 12 lbs. then stick a rubber tube in each spark plug hole and the other end in your ear (and tell everyone to be quiet). If you get lucky, you'll hear something.
Old 07-06-2010, 12:54 PM
Eljaro's Avatar
ermariachi,
its the head gasket. period. Everything beeing the same, it can not be anything else that is made out of metal.
I had to replaced an lmost new felpro headgasket because cooling liquid was oozing out of the head bolts. It was brand new and had not been abused.
After having replaced so many felpro head gaskets I decided to give the SCE Copper headgasket a try, with the silicon beads around the water passages and oil holes, which is the weak point.
I also had the head shaved to have them absolutely flat.
I have driven the cobra after that very, very hard and no issues with oil or water leaks like before.
Old 07-06-2010, 01:13 PM
Clois Harlan's Avatar
I too am sure it is the head gasket but for a quick fix the Aluminium bars stop leak works great. I have been told that many new engines get this during assembly. Fel Pro quality is not what it once was. George Anderson (Gessford Machine and Mechanic of the year) likes Victor gaskets but they are very hard to find (at least around here).
Clois
"Let's roll"
"Be part of Something Good
Old 07-06-2010, 01:26 PM
Head gaskets on this car are Cometic. We will likely try the Alumaseal last.
Old 07-06-2010, 01:34 PM
Nice to see one El helping the other el...
Chas.
Old 07-06-2010, 02:21 PM
Barnsnake's Avatar
You might want to make sure that "new" thermostat opens fully and at the right temperature.
