Old 08-17-2010, 12:42 PM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Default ford fe intake-head valve cover tolerance
does any one know what the tolerance is for the valve cover rail i have around .045 difference in the rear and a little less in the front. what is the proper way to machine is there a formular on how much to cut?.
Old 08-18-2010, 07:41 AM
Default Valve Cover Rail Mismatch
The article in the link below specifies that 0.015” and greater mismatch of the rails requires machining of the intake-to-head surface of the intake. It doesn’t address machining the bottom of the intake, but keep in mind this may be required also to keep the intake-to-block mating from holding the intake off of the heads . Take a look at the picture that precedes this one also for more intake installation tips.
http://www.carcraft.com/techarticles.../photo_16.html
Steve Christ’s “How to Rebuild Big Block Ford Engines” specifies that if the block-to-head mating surface of either the block or heads have been machined more than 0.020”, the intake will require machining on the head and block mating surfaces (pg. 101), and has a table for how much to remove from each manifold surface based on head or block machining (pg. 102). If you don’t already have this book, it is well worth it just for the wealth of information on the FE engine, even for someone never planning on rebuilding their own (Book ISBN: 0895860708).
If a man does not keep pace with his companions, perhaps it is because he hears a different rumble. Let him step to the sidepipes which he hears, however measured or far away. - H.D. Thoreau...if he had owned a Cobra
Old 08-18-2010, 08:26 AM
FWB's Avatar
FWB FWB is offline
aftermarket heads? what intake is it? does the intake stick up over the heads or visa-versa.
Fred B
Old 08-18-2010, 01:37 PM
i am using edelbrock heads and a edelbrock rpm intake
Old 08-18-2010, 02:23 PM
FWB's Avatar
FWB FWB is offline
best case is to try another intake and see if it fits the same. if it does then i would skim the intake mounting surface of the head to make them true. hopefully the heads aren't torqued yet. if you don't have another intake to try then measure on the head from the dowel pin counterbore to the intake mounting surface and compare the front measurement to the rear if they are the same then machine the intake. if they are out more than .005 then skim the head. i had a .05 difference from front to rear on my edel. heads. i skimmed them square and intake fits beautifully.
fred
Fred B
Old 08-18-2010, 02:35 PM
FWB's Avatar
FWB FWB is offline
while your at it make sure you don't have any pushrod rubbing issues.
Fred B
Old 08-18-2010, 08:01 PM
Much more that .01 will cause leakage problems. I have "crutched" bad assemblies by modifying cork valve cover gaskets - sanding a "step" into them to match the intake/head offset.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
